Question about Crosley CR248 Turntable
The needle has started to slide as playing only 30 seconds on a record
  • Crosley Master
  • 5,056 Answers
You either need a new stylus (there not called needles anymore) or the counterbalance has come loose (at the end of the arm). Therefore more weight needs to be applied.
Posted on Sep 02, 2010
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
Recorded album and first track is cut at beginning everytime
you are going from a record(vinyl) to what before you are doing the ipod? a cd or a tape..when recording the tape..remember theres 30 seconds of plastic leader on those reels..need to forward the tape past that leader to the actual tape before the recording begins..the only other thing is that some recordings that are protected will automatically screw up your recording so as to stop copyright infringement..it may be sending a purposely blank signal for a brief period..and thats encoded into the original recording..
Mar 15, 2014 | Sony Sound Forge Audio Studio 9
Needle stylus unit rubbing the record.
There's too much weight on the stylus or the needle is not inserted correctly.
May 15, 2017 | Office Equipment & Supplies
Needle sliding
Going on what little you have written, the most likely cause is a worn or bent needle. http://www.turntableneedles.com/search.asp?keyword=793-d&search=GO is the needle type that should be correct for your Teac SL-A100 Turntable.
Feb 16, 2013 | Teac SL-A100 Turntable
Needle slides across record
It could be 3 different things. The first is check the needle make sure its not dirty. the second is make sure the weight is set correctly. And the third is did you take the tone arm off the protective part that holds the tone arm in place when moving or travelling .
May 19, 2012 | Numark ttUSB Turntable
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
My record stylus slides across records
There are a couple of reasons this is happening. First and formost gently lift the stylus arm and blow any and all dust off of the needle.You may even have to gently 'pinch' off any accumulated dust. Be careful since you don't want to pull the playing needle off.
This is a very common problem. If this does not help, you need a new stylus needle for the arm.
Dec 04, 2009 | Technics SC-DV290 System
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Crosley CR248 Turntable Logo
132 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
