Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
I need a copy of schematics for my CozyBike. Batteries are brand new and intact in casing. But, the bike continues to surge in short bursts. Does not move forward and I want it fixed asap as I plan to take it to Fla. Also, some repair dealers in local area here. I'm in Danville, NH 03819
When I put in new batteries in my easy share C1530 they immediately discharge
There is an internal fault that is shorting out the batteries get it looked at before batteries explode or burst and camera internals get damaged more
Dec 31, 2015 | Kodak Easyshare C1530 14 Mp Digital Camera...
Electric bicycle
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
Mar 23, 2014 | Electric Bicycle Motor, Bike,electric...
Manual for cozy electric bike
who to put together a Cozy Electric Bike?
Jan 12, 2013 | Little Tikes Cozy Cruiser Trailer
I put 3 brand new batteries in and it still don't start not even a light will come on. Don't know what to do please help.
I have two post for your problem. In one post you say that you have installed three new batteries in your bike. All of them have have been pulled down to completely dead but you didn't say how long it took to do this. Also, not lights or anything will work on the bike. Evidently you have a serious electrical problem to say the least. If this is the case, you should be getting a tremendous spark whenever you're trying to connect the new batteries. Look behind the triangular plate on the left side of your bike and see if the fuse panel is behind the plate. Take all the fuses out and then reconnect the battery. When you connect the battery, notice if you get a spark. If you have taken the main fuse out and you're getting a spark, you have a direct short between the battery and this fuse panel. There is only one wires that goes from the battery to the fuse block. If you don't get a spark, put the main fuse back in and then the other fuses one at the time. When you go to put one of the fuses in that creates a large spark, this is the circuit that is draining your battery. You'll need a schematic to determine what electrical equipment is on this circuit. You'll have to trouble shoot each piece of equipment to find the one that is draining your battery. When doing this test, leave the ignition switch off because you should be leaving the switch off when you're not riding the bike.
Good Luck
Steve
Sep 18, 2011 | Harley Davidson XL 1200N Nightster...
Assesary fuse blowing
If you have a short circuit blowing the fuse, you're probably going to need a wiring schematic of your bike. You'll have to disconnect all devices that run off this fuse. Then reconnect them one at a time until the fuse blows or check them for contineuity to ground.
If you have added any new equipment to the bike lately, this is the place to start looking. You may not have a short in this case. You may have simply overloaded the circuit and the fuse is blowing to prevent you from melting wires.
Good luck
Steve
Aug 13, 2010 | 2005 Harley Davidson FLHR - FLHRI Road...
I have a 1993 cbr900 i bought a brand new battery and 2 days l8tr it was dead what will cause my batteries to keep getting drained while riding my bike??
The first place I would look is the voltage regulator. When they start to go out, they will continue to drain amps from the battery even when the bike is off. An ohm meter can test to see if there is continuity there when the bike is off. If so, replace the regulator. Pretty easy to test/diagnose the regulator.
Jun 11, 2010 | Motorcycles
Hi, I have a Philips SCD361 Monitor. Generally it's very good, picks up just the right level of noise. My daughter's room is across the other side of the house, so without it, I wouldn't hear her wake in...
The issue you are having could be caused by a number of things but the most likely is either interference from a transmitter in the same frequency range or the Monitor has a failing capacitor on the board.
If you can think back to when the issue first started and check to see if you have any new devices that might be on the same frequency range and test them by turning them off for a while to see if it continues though this would not be effective if you live close to anyone else.
If that does not work then use high quality batteries and make sure the unit is placed far away from any windows in the room also make sure any florescent lights are not in use near the unit and make sure its not next to any thing else that uses a power supply that has the square box on the plug that includes using the same outlet.
This particular device use's a low frequency range around 40mhz which can be prone to interference more then a lot of the newer units that use 800mhz to 2Gighz.
If all of the above fails you will have to replace the unit or seek repair from the manufacturer if it's still under any warranty.
Apr 03, 2017 | Philips Baby Care
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
53 people viewed this question
Top Electric Cycling Experts
ebike
Level 1 Expert
Eric Hidle
Level 1 Expert
Are you an Electric Cycling Expert? Answer questions, earn points and help others
