Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
My M899722t will only run on speed 5......I have replaced the togle switch and the 5 speed control switch......it still does the same thing......runs on high only....???????
  • 12,061 Answers
You problem is within the actual speed controller itself. I imagine that the Output semiconductors have gone short circuit, and this is why it will only drive at Maximum.
You need to repair or replace the actual speed controller electronics, in the unit itself.
Posted on Sep 03, 2010
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
Runs for 5 seconds and then stops
Hey Greg, the first thing that comes to mind is that the machine is not tuned correctly. If it runs in slow speed and stops when you move to a fster speed then the speed control switch needs to be adjusted, here is a site that will give you the basics on tuning.
www.youtube.com/watch?v=pUo_ZU5xh3o
I hope this helps you, please let us know if we can help further that way we can help FixYa
Aug 08, 2014 | KitchenAid KP26M1XNP Professional 600...
My cruise control does not work on my 2003 Ford Focus
Hi Fred,
There are several things that can cause your cruise control to not function. Anything from a bad speed sensor to a faulty speed control servo. It is impossible to tell you what is wrong without diagnosing your speed control system. Here is a quote from the vehicle manufacturer regarding this issue:
"Start by running speed control servo integrated self test diagnostics. The servo has integrated self test diagnostics which is a key tool in quickly and accurately diagnosing speed control system faults. Self test diagnostics are also the basis for starting speed control trouble shooting."
Please note that a diagnostic scan tool capable of accessing the speed control data is required for performing this task.
Oct 15, 2011 | 2003 Ford Focus
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Timer not working?
look closer at those pins as the motor turns those pins turn a togle switch on and off make sure those pins are able to togle that switch you will see that switch under the that timer disk
Apr 26, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Heater motor will not work on #5, it worked for 5days after resis
First check to make sure the electrical connector on your switch is o.k. if it looks burnt /brown or melted replace your switch, and the connector.If all is well then replace your blower motor, it may be drawing to much current (AMPS). Along with a new resistor block.
Jan 15, 2009 | 2004 Chevrolet TrailBlazer
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Heater motor only runs on high
Replace the heater blower resistor.
Dec 26, 2008 | 2002 Pontiac Grand Prix
Sony DSC-W50 Flash Error code-E:91:01
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 08, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
P reg 96 volvo v 40 fan switch location
it could be a fan switch relay also. or a bad connection. or any type of thing. it's best to let the volvo dealer take care of the issues. volvo's are tricky to work on and they are best equipped with highly skilled and trained volvo technicians that would know more about volvo's than any other shop around.
May 26, 2008 | 2000 Volvo V40
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
171 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
ken skalski
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
