Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All mounting screws are tight. Is there an issue going on with these GE motors? What is the issue here? Contractors have not seen this type of issue before. R-410A, Model: RANL-030-JAZ
  • Brian Niten Sep 02, 2010
    Do you know if they replaced the motor with one that had the same horsepower rating & same RPM. I have heard that a motor with a higher horsepower rating will cause some vibration.
  • khigg002 Sep 03, 2010
    All 3 motors are GE, 1/6 horsepower and 1075RPM.
  • 24 Answers
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Posted on Sep 04, 2010
I have a problem with a Rheem Power Vent Water Heater shutting down due to condensation build up.
if it,s condensation....let it sit out side in sun to dry out well then bring it in start it and with a flash light look for leaks
Aug 13, 2016 | Rheem Water Heaters
What is problem when fan motor on outdoor unit gets very hot and compressor will not restart?
Ur compressor depends on fan motor of ur condenser. Ur compressor undergoes Hi-pressure because ur fan not working properly
Sep 06, 2014 | Rheem Air Handler 3 Ton With RBHP Series
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Recently replaced entire central a/c - Removed 2,500 ton Rheem condenser - Unit is approx. 2-1/2 to 3 year old - 13 Seer - Interested in selling unit...Who made be interested in purchasing??? What would...
Hi, 2,500 ton unit would be the size of a 15,000sq.foot warehouse! I think you mean a 2 1/2 ton Rheem condenser. You could run an add under Craigs list.com, and if the unit is in good shape, I would ask no more then $600 for it. As a Contractor, I can get them anytime new for around $660.00. If you can get $500 for it jump on it. Best of luck to you,
Shastalaker7
A/C Contractor
Jul 26, 2011 | Heating & Cooling
Ruud ubhc-17j11sfd the outside unit wont come on for AC. I checked the breakers in the main breaker panel for the house. The fan inside works.
Hi!!
Did you check if the outside fan is working?? On the summer time the failure of condenser fan motors increases due to hi temps.
Have somebody turn unit on as usual while outside you check if condenser fan is turning and if the compressor kicks in. If the fan motor do not work, the compressor will shut of to prevent damage..
If either one of them tries to start but can't take off, replace starting capacitor, some units have separate capacitors and some have combo capacitors, they work the same.
If after replacing the capacitor the fan motor still don't want to start up, replace motor. If Compressor do not want to start, call a HVAC Technician to perform further testing.
Good Day!! Don't forget to rate this post!!
Aug 13, 2010 | Ruud UBHC Air Conditioner
The condenser fan motor has stopped working for the 3rd time. This unit is only 10yrs old.We have already replaced it twice.
Is it the motor or capacitor? If the capacitor is bad the motor won;t run, it will just hum or run real slow.
If it is the motor and it's the 3rd one then you need to go to a more heavy duty motor, for instance if it's a 1/4 horse power then go to a 1/3 hp. etc.
May 31, 2010 | Ruud Central System Air Conditioner
We have a rheem heat compressor pump manufactured 08/2004. compressor is not coming on. Had a tech come tonight, he said compressor is bad and a new one is very hard to find so we should look into buying a...
Check your yellow pages find a contractor who will offer free second opion on compressor failors, better yet try to find one that is a rheem dealer. If the compressor does turn out to be bad he can turn in the model and serial # to find the installation date. In most cases warranty info does start day of contractor purchase unless owner fills out and mails in warranty card. But neverless warranty ticks away while house sits unsold. Compressor does not have to be a direct replacement most any brand of compressor ( of proper capacity) will work in there but may have to do a little retrofit. Should be no problem. As for price replacing a compressor is very expensive. About the most expensive thing to replace. It is definetly easier and quicker to just change out the unit. Get a few quotes keep in mind after replacing comressor some other part of unit could go bad costing more money.
Oct 07, 2009 | Heating & Cooling
American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Jun 28, 2009 | Heating & Cooling
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
