Question about Porter Cable 423MAG Factory Reconditioned 7 1/4" Quik Change Blade Left Mag Saw Kit
My trusty PC 7 1/4",15 amp after many years simply stopped running .no electric/burniing smell. hoe do i diagnos burnt out motor versus cord/switch break?
  • Porter Cable Master
  • 885 Answers
Check the carbon brushes by removing the black cover on the end of the motor. The brushes should be long enough so the spring can hold them firmly against the armature. The end of the brushes should be slightly concave and smooth/shiney. If they are worn down too short or look broken and don't touch the armature replace them. If the brushes are OK, take the right half of the handle off, should be five or six screws. Look for any burn marks or melted wires along the cord and switch wires. Use an electrical multimeter set to AC in the 200V range. Plug the cord in and check for voltage where the cord goes into the switch. If no voltage, replace cord; voltage, move on. If the switch can be locked on do so, otherwise you'll have to have someone hold it on while you check for voltage on the out side of the switch. Again no voltage, replace the switch; voltage move on. If you have power going into and coming out of the switch and the brushes are OK you may have a problem with the armature or field. These have to be tested with a growler to check for shorts. Most electronic shops have one.
Posted on Sep 02, 2010
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Motor is random like a short
It sounds like you probably have a bad spot in the cord. What happens is you get a kink in a spot or you run over the cord and it loses continuity there, but only when it's bent a certain way. Turn it on and wiggle the cord from one end to the other I think you'll find the problem there.
Otherwise, if that isn't it, your motor is possibly the problem. Does it smell like burnt electrical when its running? A frozen motor carbon brush will cause this or just plain worn out carbons can do it as well.
Lastly It could be the switch but they generally just stop working and its on or off and no in between.
I'd bet it's the cord.
Happy Vacuuming!
The Vac Dr
http://vacuummedic.com/product.php?id=181
Jan 13, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
May 05, 2011 | Black & Decker 19" Electric Lawnhog...
Using my unit (owned about 6 years - great service so far) it suddenly quit ... no wind down or 'prelude' like whine - growl - etc. -- it just quit running ... suggestions? clear filters?...
I agree with you having great service because mine only lasted two years. It sounds like the motor just worn out. If you don't smell any burnt electrical then replace the bushing for the motor. Good Luck
Jan 07, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
I have a sunbeam mixmaster from an Aunt that is at least 30 years old and it recently just stopped working. I assume that the motor is blown. Is it possible or worth it to fix it ?
If the motor is blown it will most likely cost more to repair or replace the motor than buying a new mixer. However, It could be a break in the electrical cord or at the plug. Is there a 'burnt' smell in the mixer? If not, have the electrical cord checked by someone in the know before purchasing a new mixer.
Please don't hesitate to ask me should you need any more info.
Best wishes,
Graeme.
Nov 30, 2010 | Sunbeam Food Mixers
My goodman electric/gas pack started smelling like burnt motor then stopped blowing then shut down. Blower motor? (yes /no) What is replcement procedure..
(yes/no) verify the motor is bad by volt, amp draw, and ohmmeter. if bad, the repalcement is fairly straight forward the entire squirrel cage assembly is removed, cleaned, new motor and capacitor installed and then wired back in. Goodman has a five year warranty program on many of it's units, verify before spending money on a motor
Jul 06, 2009 | Heating & Cooling
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Maytag Neptune Dryer not heating
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Porter Cable 423MAG Factory Reconditioned 7 1/4" Quik Change Blade Left Mag Saw Kit Logo
161 people viewed this question
Top Porter Cable Saws Experts
Dave
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
