Question about Dell Computers & Internet
I have a Dell Inspiron 8200 laptop. It powers back down within 1 to 2 seconds after powering up. I hope you can give some suggestions.
    Brigadier General:
  • 3,917 Answers
Hi
Remove any add-on component (like any external USB connections)
Remove any disc in the CD drive
Try blowing out the fan again (actually you may need to really open the laptop up, and clean and re-paste the CPU heat sink but this is difficult)
Also reset and blow dust away from the Ram card(s) .Also your battery may also be bad or your power supply or your internal regulator.
Take the battery out and try, battery maybe bad.
It could be the charger and the battery, if it’s not the battery or charger then its likely the mother board
Try this link if it helps:-
http://en.kioskea.net/forum/affich-22454-screen-goes-blank-after-starting-windows
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 02, 2010
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My dell inspiron mini 10 wont power up at all with charger and only gives me a brief white light when battery and charger are plugged in. Any suggestions
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | Dell Inspiron Mini 10 Notebook
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Dell PP29L backlight turns off on external power
I'd try:
Updating the bios to the latest version
Uninstall video driver and check for newer version
Replace the inverter.
Let me know if any of those suggestions work, if not we can try something else.
Apr 03, 2010 | Dell Inspiron 1525 Laptop
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
My dell 8200 inspiron laptop right speaker its not working
My guess is the speakers or connectors have gone bad. I have seen this in a lot of different laptops.
If you are handy, you can disasemble the laptop, find the speakers, and get a part number off of them. Dell is pretty good about labeling the part numbers. Then do a search on Google and Ebay for the speakers, I am sure you can find some cheap used ones that work.
Here is a manual for disassembly of your laptop, and shows where all the parts go. You will need Adobe reader to read this.
http://www.elhvb.com/mobokive/edwin/laptops/Dell/INSPIRON/8200/8200.PDF
Apr 14, 2009 | Dell Inspiron 8200 Notebook
Boot problem
sounds like a bad driver-can you boot into safe mode? how about the bios?
Apr 09, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Mar 24, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 8200 Battery
I assume that you have your charger plugged in as long as you use the laptop...
There are very minimal chances o the battery having been damaged, since the casing on the inspiron 8200 is quite sturdy.. i suggest you get the charge socket (the socket that leads to the main wall electricity outlet) from a qualified technician...
Feb 26, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Hang
There is not a reset button that model. The only other way to force restart it would be to unplug the computer from the outlet. This is not a recommended method but, it can be used a last resort if your computer is hanging.
Jan 09, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
12 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
