Question about ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor
E7oFb viewsonic crt monitor a brightness/contrast screen is appearing
  • 4,234 Answers
I don't know this particular model, but there are a few things you can check should you wish to retain the monitor.
1) If the unit has the older rotating controls, try spraying them with electronics switch cleaner (with lubricant). Work them back and forth a few times with the power off.
2) If the controls are the tact switch type, with the power off, press all of them and you should feel them engage. If not, replace the switches. They should be available generically for about 25-50 cents each.
Dan
Posted on Sep 02, 2010
  • ViewSonic Master
  • 3,866 Answers
Had the same issue I do have this monitor by the way.
The control board on the front where the buttons are at is what the cause is, Now this monitor is pretty old not like you going to find parts for it, I mean you can check ebay and what not Good luck, But its going to need a new control board.
The Bright/Contrast window, controlled from the monitor itself, keeps popping up. The select pane continues to switch between the Bright selection and the Contrast selection. When it finally stops...
Sounds like your monitor is going bad. You might get some more use out of it if you power it off for a couple hours and try again but my guess is this is a heat-related failure that is common on ViewSonic monitors.
Jun 30, 2017 | ViewSonic Vx2250wmled LCD Monitor
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
The brightness/contrast window pop up randomly and frequently. Brightness level keep on increasing automatically. Pls help.
A 15-inch CRT monitor? It's time to responsibly recycle it, and buy a 17-inch LCD monitor, because _nobody_ fixes CRT monitors any more.
Jul 03, 2010 | ViewSonic E50C 15" CRT Monitor
The brightness and contrats always appears on the screen.It increases and decreases frequently...
This problem is due to a defective microswitch in the brightness and contrast button of your monitor. To rectify this problem, you'll have to replace this microswitch. Please refer the servicing to a trained repair technician.
Hope this solves your problem. Thanks.
Aug 24, 2009 | ViewSonic E70f 17" CRT Monitor
Brightness and contrast control screen always appears on screen
It is a disguisting problem which I am myself facing. This causes due to moisture on the monitor curcuit components and the curcuit pads get pressed. This can only be solved when by replacing rusted parts. Contact a monitor enjineer.
Aug 16, 2009 | ViewSonic E70f 17" CRT Monitor
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70fB Brightness & Contrast problem
Sounds like the buttons or the button panel are messed up. Or it has gotten moisture in it.
The only time i have seen this was when one of the buttons were malfunctioning, and we ended up replacing the monitor.
Oct 03, 2017 | ViewSonic E70fb 17" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Logo
136 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
