Question about HP Laserjet P4015x Printer
Top lid will not close after fixing a paper jam
  • 241 Answers
Often times the lid will not close if the toner cartridge is out of place. Will the lid close with the toner cartridge removed? If it does then reinstall the toner cartridge and make sure that it is fully seated.
Posted on Sep 02, 2010
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Printhead cartridge jams
Hello, sorry took so long but, seems to be a paper jam or loose ink cartridge, open lid with unit unplugged and try and see any paper jammed in rollers or pieces of paper, then with that done and hopefully fixed but if not, close lid and turn unit on then open lid to access print cartridges make sure they are installed right and the right ones in the right slots if the cartridge unit don't move so as to load cartridges in try to gently pull it to position as a cartridge may have not been locked in or jarred loose.good luck hope this is of some help.
Dec 09, 2011 | Kodak   ESP5250 Es Printer
How do I fix paper jam? Or reset the printer after I pulled the paper out?
The whole top half lifts open (scan-bed and all) When you have cleared the jam, close the lid and press the OK or check-mark button on front. If you like, you can unplug it for a moment and then replug to initiate a restart. Good luck:)
Aug 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Laser Jet 4250N Is The jam code B.20.00 paper jam in tray 2..... a service call or can i try to fix it myself?
You should be able to clear this jam yourself
Open the top cover and remove the toner cartridge.
Look inside for jammed paper, and remove it.
Reinstall the toner cartridge and close the lid.
Try that....
Dec 01, 2009 | HP Office Equipment & Supplies
Paper jam near fuser - OKI C5100n
okay, I have this problem I think. It is jamming on the OUTPUT side of the fuser, and I have replaced the fuser with a new one.
I learned tonight, through trying various things, that it will not jam with the printer lid open. (you can make it "print" with the lid open if you push the lid switch in so that the printer thinks it is closed. That made me wonder if it had anything to do with the led strips (black bars attached to the lid) so just for fun I unplugged the C led strip so that it wouldn't produce any light onto the drum. With the lid closed and the C disconnected, the printer will not jam. (but you get no blue on the page of course!) when I re-connect the C led strip, it jams on the output side of the fuser every time. It is very consistent.
I don't understand how putting blue toner on a paper can make it curl so much that it jams up in the fuser, but it does.
I'm sure there is something else gong on here that I don't fully understand- hopefully someone who knows more than I do can use this info to help us all out a little.
I'm going to go and fiddle with the drums now. I don't have an extra one right now, but I'll see if I can narrow it down further.
Sep 11, 2008 | OKI C5100n Laser Printer
Close Top Cover Error message does not go away
I just had the same problem... I gently bent out the double-forked copper contacts on either side of the underside of the lid top (they're flattened, two pronged with a small dimple in each bend), and that fixed the problem. Be careful not to break them off... I'm sure that would cause a much bigger headache.
Aug 04, 2008 | Xerox Phaser 7300DN Laser Printer
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP Laserjet P4015x Printer Logo
176 people viewed this question
Seeker5211
Seeker5211
