Question about Kenmore Refrigerators
Our fridge leaks water on the inside. The model # is 69862990. Serial # is EJ0336506. Type C18TFA95. The water is coming from the top rear of the fridge. Thank you.
SOURCE: Leaking water inside fridge
With mine I turned it off for 24 hours until totally defrosted. Checked behind the panel of the freezer and removed one stubborn piece of ice. When I restared the fridge it was all good. I have this problem when we have had a lot of humid weather.
Posted on Mar 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 13, 2009
localwonder
  • 6784 Answers
SOURCE: TOP MOUNT FRIDGE WATER LEAKING INSIDE OF UNIT UNIT
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
Posted on Mar 22, 2010
toolkits
  • 1099 Answers
SOURCE: Hi, I have a 2003 Kenmore
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Hope this helpout.......
Posted on Jul 29, 2010
  • 4 Answers
SOURCE: LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Posted on Jan 16, 2011
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Refridgerator Leaks
I can't find this model number anywhere and am unfamiliar with the "Evolution" series. However, if it is a top/bottom unit (freezer on top, fridge on bottom) it sounds like you have a clogged drain.
If you pull the back panel off inside of the freezer (where the evaporator is housed) you will see a drain hole, usually in the rear center) that is probably full of ice. If this drain is plugged, it will cause the water to back up into the refrigerator, usually onto the top shelf or under the veggie bins, and possibly onto the floor.
You need to clear it out, and make sure that water flows through it freely, to the pan underneath the unit. The best way to do this is with a hair dryer and a copper wire, but be careful not to melt the inside of the freezer with it. When it's clear, you might want to take a hose and blow through it to make sure there's nothing trapped inside.
Please let me know if you need any further help with this issue.
Mar 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
113 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
