Question about E-Machines eMachines Desktop PC
Power button wiring
I have three wires that come from front of machine one says power led, next one says hdd led, next one says power, what I need to know is where they plug onto the motherboard at? I had taken it to a shop he unplugged everything. emachine w2040
  • 1 more comment
  • Anonymous May 25, 2008
    ok i got model#w4682 and the same problem where does the power button wirers go?i have 3 thanks joey
  • seniyan Mar 08, 2009
    The pc doesn't turn off after windows OS close..
    desktop emachines A26EV17F motherboard AM37
  • Anonymous Mar 25, 2014
    where to plug power wires on motherboard
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
Posted on May 10, 2008
T6216
There should be 2 rows of pins in parallel usually around the bottom edge of the motherboard. The markings for which is which should be next to them on the board. HDled+, HdLed-, PwrSw, PwrLed, or something similar.
If you do find them but the hard drive Led does'nt come on it's because the plug for it needs to be turned around the opposite way, Led's only work one way as they are diodes. Same for the Power Led.
If there are no letters near the pins then you would have to find the motherboard manual.
Jan 28, 2012 | E-Machines eMachines Desktop PC
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
Hello i have a e-machine T3103 the three set of
There is a small block of pins usually on the bottom right corner of the mother board to hook up front panel connections, you will have to read the board around it and somewhere it will tell you which wires go where.
Mar 02, 2010 | E-Machines Computers & Internet
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
Basically my on buttong got stuck and when I was trying to get it out the front cover thing came of. Together the wires also came out.On the end of the wires it has...(POW S/W),(POW LED),(HDD LED). Please...
Ha Ha Ha, well your front cover thing is where your power on button and LED lights reside. the POW is your power wire that connects to your power switch you pried out of your front cover thing, or your power switch. Your POW LED is the wire that connects to the light that lets you know your computer is on and running on your front cover thing. and of course the other wire connects to the other LED light on your front cover thing. Good Luck. also, you can change the wires around until you get it right.
Oct 28, 2008 | E-Machines Computers & Internet
E-Machines eMachines Desktop PC Logo
599 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
