Question about BenQ FP92G+S (Black,Sylver) (Silver, Black) 19" Monitor
Benq FP92G screen blank, power lit not lit either. Tried different cables but still the same.
  • 11,361 Answers
More likely to have power supply problem, that will be the first place to check, look to see if it has any caps with leaking/bulging tops/seal, burnt spots, shorted transistors in the backlight inverter board, cold solder joints. Look at my DELL albums (BenQ made a lot of monitors for DELL). Be real careful when removing the front bezel, you can easily rip apart the cable.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 02, 2010
Testimonial: "Thanks for the quick response."
I press the power button it lights for a second then turns off screen does not come on
Doesn't sound good this sounds like the monitor it shot or the video card is shot If you have another monitor try it ad see if the video card is still working if it does the same thing then it is not the monitors
May 24, 2011 | BenQ FP92G 19" Monitor
My screen has gone off and won't come on at all
It may ahve power supply problem due to bad caps, blown fuse, cold solder joints. You need to open it up and troubleshoot it. Please read my guide and look at DELL albums (BenQ makes monitors for DELL).
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Oct 28, 2010 | BenQ FP92G 19" Monitor
My screen size is long and thin for my BENQ FP92G. Please advise how I fix it. Roger Perkins
change display resolutions, go to panel control , display icon and change the resolutions , tray many options
Aug 01, 2010 | BenQ FP92G 19" Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
BENQ G2200W LCD Monitor has a vertical line
Try it on another computer, if the problem is apparent on 2 different computers the monitor is defective.
Jul 15, 2017 | BenQ 22" G2200w LCD Monitor
No display, screen is blank even compuer is running
Can I assume (?) you re-tried firmly checking each cable connection and the power supply is soundly in place including checking the fuse in the plug That's all I can suggest as the things I would do if in your shoes.
Aug 05, 2017 | BenQ FP72G (Black, Silver) 17 inch LCD...
BenQ LCD DV3250
Hi...there,
Well, have you try plugged into a different port like a DVI port. If you don't got one try replaced with another VGA cable.
Sep 26, 2008 | BenQ FP71G 17" LCD Monitor
Benq 19" monitor not working every time when computer started
Check your connections and make sure they are tight, and there are no bent pins. If everything seems ok, you might want to try plugging this monitor into a different computer or plug a different
monitor into yours to determine whether it's the monitor, the video card, or maybe the driver (doubtful on this as you state it seems to be bad somethimes on boot).
May 26, 2008 | BenQ Computers & Internet
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
BenQ FP92G+S (Black,Sylver) (Silver, Black) 19" Monitor Logo
176 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
