Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
MY THREAD KEEP BRAKING - Singer CE-200 Quantum Futura Computerized Sewing Machine
  • Singer Master
  • 7,365 Answers
It could be several things
check the needle to see if bent-roll on flat surface to see if it roll correctly
if the needle makes a popping sound when it penetrates the fabric is blunt
check to make sure the needle is not in backwards
check upper tension it may be to tight
thread may be hanging up in bobbin area-clean bobbin case area for lint or loose threads
check to make sure the thread is not caught somewhere
try using different thread
Posted on Sep 02, 2010
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Install a brand new needle.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Sewing Machine Thread Keeps Breaking
Why is my thread breaking
Sewing Machine Problem 1 Thread Breakage
Feb 11, 2016 | Brother Sewing Machines
The thread keeps on breaking. I want to have the machine serviced. How often must it be done and where?
How old is your thread? Old thread will break fairly easy, also you want just enough drag to keep the thread from over feeding but not so tight it will brake thread
Jan 13, 2015 | Sewing Machines
The top thread keeps braking janome 1600pdp
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 28, 2014 | Sewing Machines
The thread is kinking and braking at the needle's eye opening and skipping.
The needle thread breaks
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 15, 2012 | Juki Sewing Machines
Needle keeps braking on the juki sewing machines ddl 555on
Hi - not an expert but from my own experience would look at two main possibilities, a) thread tension is too tight or b) the needle holder has got out of alignment
Aug 24, 2012 | Sewing Machines
Jucan`t thread serger 920d thread keeps braking
here are some suggestions
Is machine threaded correctly, check each thread guide, all tension dics
Are needles inserted correctly
Are the needles bent or damaged
Is tension adjusted to tightly
Is tension adjusted to accommodate thickness of thread being used
Are you using good quality thread
Is thread feeding off cone/spool freely
Is the needle size correct for the type of fabric being used
Are the needles being used the correct ones for the machine
Sep 21, 2011 | Brother Lay-In Thread Serger Mechanical...
My string keeps braking at the tension discs how can I elimante this to keep sewing
Lower the tension on the discs and double check the routing of the thread.
Apr 29, 2010 | Simplicity Performer S110 Mechanical...
Braking thred
Chance the needle making sure it is aligned when you tighten it. Check the bobbin to see if it is bound up by thread and the last thing is try another bobbin.
Aug 17, 2009 | Consew Sewing Machines
Thred keeps braking
It might be tension to tight, threaded wrong or the bobin isn't thread the right way.
Apr 17, 2009 | Kenmore 15208 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
51 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
