Question about Dryers
It worked yesterday with no problems, I removed clothes from dryer and put in another load, set the settings the timer started ticking, pushed the button and nothing
  • 1 more comment
  • dqmama Sep 02, 2010
    The belt is on and in place. Model serial # is 96272100 62721 and the serial # is MC4689755
    It does click when you shut it
    Already had that part suggested, I took it and the door switch to the parts store had them tested and it was the thermal fuse only, so I bought one and am now n the process of putting it on. Thanks for your time and patience in this matter.
  • Dryers Master
  • 2,605 Answers
Welcome to FixYa.
Based on the description you`ve provided I suspect a broken belt...or ar least off of the drum. On most dryers if this occurs there is a safety shut-off in the event the belt breaks or comes off.
If you could provide a model number I could help you further as to what and where to look.
I`ll watch for your reply here.
Macmarkus :)
Posted on Sep 02, 2010
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Sep 02, 2010
    Thanks for providing the model number. The number indicates it is a Kenmore manufactured by Whirlpool.
    So you`ve obviously inspected the unit to some degree as you`ve stated the belt is intact. What about the door switch ?
    If you open the door you should see a small actuater/lever which tells the unit the door is closed. If the switch is faulty or the latch has broken ( as they have been known to do ) this will also manifest in the manner you`ve described.
    When pushing it you should hear a distinctive "click" as it closes and opens upon release.
    It will look like this...part # 691581
    This part activates the door switch as I alluded to and fits over 2517 dryers, within the following brands: Estate, Kenmore, Kenmore Elite, Kitchenaid, Roper, Sears, Whirlpool, Inglis to name a few.
    The switch kit ( which includes the actuator ) will look like this...
    Either is available at most appliance part depots.
    Let me know how you make out and I will reply asap.
    macmarkus :)
  • Mark MacDonald
    Hello again,
    Sorry I wasn`t able to reply sooner. So to pick up where you left off, the switch does "click", that typically means it`s good.
    The other possible culprit is at the back of the dryer, the "thermal fuse". You`ll need an ohm-meter to check it or be capable of "jumping" it out ( join the wires together via electrical tape or alligator clamp wire jumper ) for a test.
    **Do not operate the unit like this other than testing purposes, it is there for a reason**
    It is located on the blower/lint screen housing and usually has two blue or brown wires going to it...color won`t matter, just look for the fuse like the image below.
    **again, insure the dryer is unplugged or the breaker turned off...safety first**
    Let me know what you find.
    Macmarkus :)
  • Mark MacDonald
    Awesome !
    Glad I could help and happy you are confident of the solution.
    Thank you for choosing FixYa. Please take a moment to rate the info and solution provided for you here today.
    Regards,
    Macmarkus :)
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
Kenmore dryer...65852 timer switch does not work. dryer starts on its own when I shut the door and bi passes the push/start dryer button. Can a woman fix this?
Good day,
Ma'm I don't know your mechanical background. So you'll have to be your own judge
One cause could be the contacts in the push to start switch welded together.
Even though it might appear to go in and out properly, the insides of the switch are bad.
Remove the back cover of the consule. Remove one of the wires connected to the push to start switch, and tape up end to prevent shorting.
Plug machine back in and test. If it won't start, then the push to start switch is bad, and needs replaced.
If the push to start switch is not the problem, then it would be the centrifugal switch in the main motor itself. Here is a tutorial on accessing the motor. A major job, with some complications involving the blower wheel.
http://www.applianceaid.com/wpmotor-change.html
P.S. If the dryer performs normally other then the starting problem, there is no reason you cannot use it indefinately
There was a time when dryers had no push to start function.
Proceedure was, with the timer off, and door open, load cloths, set timer, close door. Works great.
Jan 02, 2010 | Dryers
Dried a load of clothes and put another load in and now it's not working. Timer is clicking, but when I push the start button it does not kick on. Tried different settings and still nothing. It's been...
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Clothes dryer troubleshooting
my kenmore dryer keeps on drying after the alotted time has expired, i think the timer is the problem. how can i verify and fix this??
teddy
Oct 27, 2007 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
