Question about NetGear DGND3300 RANGEMAX DUAL BAND WIRELESS-N DSL GATEWAY Router
How can I edit netgear.cfg? I want to set manually on file the QOS portion. Can you get ne a sample of QoS seting: fior App, Game, IP, MAC with min and max priority? Thanks, Mihai
5 Suggested Answers
  • 196 Answers
SOURCE: Setting Up QoS (Quality of Service) Settings on the WRT54G
What is QoS? QoS is a popular feature that ?guarantees? better service to selected traffic on a network. The goal in configuring QoS is to give priority and attention to certain devices or services so that they can use the maximum available throughput and speed available on a certain network when it is needed. Accessing the Router?s Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Enabling and Configuring QoS 1. Once in the Router?s Setup page, click on the Applications and Gaming tab. 2. Next, click o n the QoS sub-tab. 3. Select the Enable option to turn on QoS features. NOTE: If you do not see the QoS sub-tab, you must upgrade your router?s firmware to the latest version. See Answer ID 1508 for more information. The WRT54G offers three (3) different types of Quality of Service (QoS) options: MAC Address-based, Application-based, and Port-based. Choose the appropriate type for your needs. · MAC Address-based QoS: In the Device Priority section, you can specify the hardware MAC address of the computer or device that you wish to give priority to. You can assign a Low or High priority for up to two (2) specific MAC addresses found on your local network. · Port-based QoS: In the Ethernet Port Priority section, you can control bandwidth according to which of the physical LAN ports your computer or device is plugged into. You can assign a Low or High priority to computers or devices connected to any of the router?s LAN ports (1 through 4). NOTE: You can also Enable or Disable ?Flow Control? for each LAN port, which is a technique that controls the speed at which data is received. If Flow Control is enabled for a certain port, then a receiving device is not overwhelmed with data as it is coming in. You can even control the flow further by specifying the Incoming Rate Limit to a certain speed. · Application-based QoS: In the Application Priority section, you can control bandwidth with respect to a specific application being used on the network. You can assign a Low or High priority to a particular application or service. There are several pre-configured Web services that use well-known ports, like FTP and HTTP, which you can use. You can also customize up to three different applications by entering an Application Name and the Specific Port # that the software application uses. If you are unsure of the port number that is used for a particular application, contact the software manufacturer for more information. 4. When you have finished configuring QoS settings, click on Save Settings button to save your changes.
Posted on Feb 16, 2006
  • 5 Answers
SOURCE: QOS on D-link dir-625
buy a linksys wrg series router and smash that dlink peice of junk into tiny little pieces, put them into a bag and mail to dlink, with a letter describing your opinion of their products.
Posted on Jan 31, 2008
  • 19 Answers
SOURCE: D-Link DIR-625
What you need to do is long into your router's configuration. For the D-links, all you have to do is open internet explorer. Type in 192.168.0.1 on the address bar and press enter. Once you get into the log in page, type in your username and password (not the same one as your wireless password). If you don't know. Try admin for username and leave password blank. It should work if you have not change the default password. Once inside the configuration page. Go to Advance, click on QoS engine on the left. Input the IP address of the VoIP box in the "source ip" , type in a name for your rule and select 1 for priority and input your ports for your VoIP box. The best thing you want to do is put your VoIP box before your router. That way you get better quality.
Posted on Oct 03, 2008
SOURCE: Applying QoS to WNDR3300
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
Posted on Jul 30, 2009
Network keeps on crashing
Try turning QOS off on your router. Generally, with home routers, QOS causes issues. What are your download and upload speeds? If you don't know you can go to speedtest.net and it will tell you. If turning off QOS doesn't resolve your issue and you have decent Upload/Download Speeds (3mbps/20mbps or higher) then your best bet would be to replace your wireless router.
Apr 14, 2017 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a nortel tasman 1004 with 1 t1 port licensed. I need to have it reconfigured to a new location with new ip address and updated software if possible... I have tried to program it myself and keep...
Here are some commands to configure your tasman router :
tasman> sh configuration runn Please wait... (up to a minute)
terminal exit terminal qos exit qos module t1 1 clock_source line alarms thresholds exit thresholds exit alarms linemode exit linemode exit t1 module t1 2 clock_source line alarms thresholds exit thresholds exit alarms linemode exit linemode exit t1 interface ethernet 0 ip address 66.201.12.x 255.255.255.0 <------- for example ip multicast ospfrip2 icmp exit icmp qos exit qos vrrp_mode 0 exit ethernet interface ethernet 0.1 ip address 62.18.3.0 255.255.255.0 <------ for example ip multicast ospfrip2 icmp exit icmp qos exit qos vrrp_mode 0 exit ethernet interface ethernet 1 icmp exit icmp qos exit qos exit ethernet interface bundle MFR1 link t1 1 link t1 2 encapsulation frelay fr intf_type dte frame_size 4470 mfr fragment_size 4000 mfr seg_threshold 3999 lmi ansi exit lmi pvc 500 shaping cir 3072000 bcmax 3072000 bcmin 65536 no policing ip address 15.10.16.86 255.255.255.252 <------ WAN IP address to ISPicmp exit icmp red exit red exit pvc exit fr icmp exit icmp qos exit qos exit bundle aaa radius exit radius exit aaa snmp system_id tasman1 enable_trap exit enable_trap exit snmp hostname tasman telnet_banner exit telnet_banner event exit event system logging syslog exit syslog exit logging ip load_balance per_flowroute 0.0.0.0 0.0.0.0 15.10.16. 85 1exit ipfirewall globalalgsexit algsmax-connection-limit self 2048exit firewall firewall internetexit firewallfirewall corppolicy 1024 out permitexit policyexit firewallpolicy community_list exit community_list tasman>
Or use the link below:http://www.ipbalance.com/vendor/tasman-networks/454-mlfr-boundle-serivce-configuration-for-tasman1004-router.html
Dec 04, 2011 | Nortel Networks SR1004 4P ACTIVE T1 ...
When setting up QOS. What does a data vendor need
"auto qos voip cisco-phone" on poe port, "auto qos voip trust" on both ends of the uplink trunk.
Feb 11, 2010 | NEC Computers & Internet
I have a DG834V4 adsl2 modem/router. When I use yahoo messenger voice or windows live messenger voice, the audio in is distorted as if only ½ the signal is getting through. Have changed sound card,...
I use a DG834 as well. It has QoS (Quality of Service) disabled by default I believe.
Sign into your modem, Internet Explorer/Firefox type the address 192.168.0.1 into the address bar, user name is admin, password is password. Under advanced on the left hand side open QoS. You can edit the priority of traffic. Set Live Messenger to highest priority, and adjust the others as to your preference, make sure Enable WMM is _NOT_ ticked and Internet Access QoS is on.
Let me know how you go, or if you require further assistance.
Aug 21, 2009 | NetGear Computers & Internet
Jul 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Cant obtain ip adress
Have you set up your lynksys to allow wireless QoS? If not go to your lynksys broadband wireless software. If you don't know how enter 192.168.1.1 into your explorer bar, log in with lynksys, default is top line blank password 'admin', go to Applications and Gaming tab and enable Wireless QoS, you'll also see all of the places to establish and open ports for specific applications.
May 09, 2009 | Linksys WRT160N Wireless Router
Applying QOS to a VLAN on a procurve 2626
Need to config the diffserv you want to program
Example: config t=qos dscp-map 101110 priority 6
Need to set it to the Vlan
config t(vlan 101)= qos dscp 101110
ip address 192.168.101.2 255.255.255.0
qos dscp 101110
voice
exit
This a a common differ-serv 46 priority 6 for IP phone system
Dec 05, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Ip address,subnetmask,primary dns,secondary dns,default router,
they should be given by the internet provider or you can try the following:
on a computer connected to the internet..go to the run menu(windows key and r key)
type cmd
a command prompt will open
in that type ipconfig/all
hope it helps!
Nov 29, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Feb 16, 2006 | Linksys (WRT54GC) Router
NetGear DGND3300 RANGEMAX DUAL BAND WIRELESS-N DSL GATEWAY Router Logo
965 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
