Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How to adjust self propelled on lawn boy modle 10682 traction is not as good when new slow almost need to push the mower
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
SOURCE: no spark
After seeing what you and other ASK type web sites charged to answer my question, i called the dealer he answered the question for me. i ordered the part online and repaired it myself.
My advise before you pay anyone to answer your question try calling a local repair center, i found they were willing to answer my questions without a CHARGE
Posted on May 19, 2009
rockitman187
  • 2559 Answers
SOURCE: My daughter called said she hit a stick with her new lawn boy mow
Check and see if the belt for the drive wheels is still on the pulleys.
Posted on May 20, 2009
SOURCE: Troy Built 6.75 Self Propelled to Slow
You have to take off a part behind the gears and move it to a slot farther away. Mine was the same way. It's in the manual on how to adjust the speed to go faster.
Posted on May 30, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Model 10640 how to adjust self-propel drive cable
If the V-belt is old, you'll need to install a new V-belt first ,then IIRC,the adjustment is by sliding the bale conduit on the side of the handle.
Jun 16, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I can push the handle all the way in, but I get very little speed from the mower.
Your throttle cable likely needs adjusting.
It should be fastened on the engine with a screw. Loosen that screw and adjust while engine is running then tighten Keep fingers away from underneath while engine is running.
Oct 05, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Rerunning the belt on an o6 self-propelled Lawnboy
You may have to loosen the adjustment a bit to let the transmission tilt farther forward. Do not loosen the other nut on the adjustment, that way you will know how far to re-tighten the one you loosened when you have the belt on.
Apr 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,576 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
