Question about Abit BH7-E Motherboard
My PC will no longer boot up and I am sure its the motherboard at fault. I get a beep every 2 or 3 seconds and there is a red warning light on board. What are these symptoms telling me?
    President:
  • 1,851 Answers
As you describe the beeps it seems to be ram failure. In case of 2 (or more) chips remove one after the other and try to locate the problem chip.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 02, 2010
  • 11,800 Answers
That the memory is inaccessible - try to boot using another memory, if it's the same then the northbridge has failed = replace the motherboard.
What does the different warning signals of asus p5vd2-mx mean?
The POST code error for this is -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Jul 16, 2012 | ASUS P5VD2-MX Motherboard
Abit NF-M2SV board. Has begun failing to startup, the power switch is pressed, then shortly after ( anything from around 5 seconds to 30 seconds ) the power shuts off, so that pc is unable to boot. I have...
Try to rule out the external devices such as RAM/ video card/ internal modem/.If it still the same thing reseating the processor and heatsink can rectify your problem.
Dec 27, 2010 | Computers & Internet
Asus rampage 2 extreme no beeps on first boot, does not enter post, i.e nothing shows up on screen, with the 8 pin power connector in the motherboard the pc will boot then shutdown for 2 seconds and reboot...
1 - Test the memory in another pc; if it's at fault change it completely.
2 - That 8 pin connector is there to provide extra power to the processor sources - either one or more of them are fried = replace motherboard or the processor itself is gone =  test it in another pc and replace it if necessary.
Oct 25, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
No boot
It is the motherboard's fault...
Apr 09, 2009 | Computers & Internet
No boot
Check to make sure you don't have any extra standoffs under the motherboard that may be shorting it out.
Nov 02, 2008 | Intel DG965WH Motherboard
Screen wont come on
If you don't hear any beeps and your laptop is connected to the charger then most likely the motherboard or vga chipset has failed.
Mar 23, 2008 | HP Compaq nc6000 Notebook
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Abit BH7-E Motherboard Logo
123 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
