Question about Brother Office Equipment & Supplies
Item: Brother fax 2920 super g3 33.6 Kbps We are trying to change an existing one-touch/speed-dial number but cannot operate the cursor? email address: sue@eurotubes.co.uk
I saw your question on fixya.com. I am having the exact same problem. Are you getting 3 beeps when you try to operate the cursor? Apparently this means one of the buttons is stuck and the you have to clean the buttons with a wipe and try to "unstick" them. I have cleaned mine but unfortunately the problem remains unsolved I hope you will / have had better luck. To get help from Brother ring: 0161 615 6200
Posted on Feb 22, 2011
Brother intellifax 2920 manual
Send me an email to LBrown18062@hotmail.com and I will send the manual to you right away. Please put "Brother Fax 2920 Manual" as the subject. Lawrence Brown
Nov 28, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
Brother 2920 display unable to print pleas help me
hi
check the cable connection
check if you have toner in
check the drivers
Jan 15, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
I have a intelifax 2920 Super G fax machine that has lines horizontally through the page, just one every 4 inches on the pages that are faxed in
This is a drum defect. You are going to have to replace the drum unit. I have seen this so many times I have lost count. The drum unit is the part that your toner cartridges are installed into. Just order one in and replace it. The lines will go away.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Brother IntelliFax-2920 Plain Paper Fax,...
Changed the toner but it still says "unable to print"
Put the old tone back in machine. Does the problem still exist? If not try another new toner.
If it does then you may have a mechnical failure which will require a service center.
Apr 15, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
OUT OF MEMORY
Go into the printer settings on the computer and change it from-send dirrectly to printer - to - Spooling. It will send a small portion of the print job at a time there for the printer mempry will not overload and report out of memory. Please rate this help if it works for you. Thanks!
Jan 28, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
WHAT IS ERROR #202 MEANS
hello! i just checked the dervice manual for the rror202 that you said that you are having did not find that code could you clarify thanks brother sr tech
Jan 22, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
306 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
