Question about Electrical Supplies
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel. Sprayed ether into air filter, starts for 3 or 4 seconds and dies. Will not continue running. Any idea. Generator only 2 years old.
  • 90 Answers
The worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Posted on Sep 02, 2010
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Last time used 18 months ago, ran good, no problems. Tried to start it and it won't go...So I checked oil level..(good) removed the fuel bowl replaced old fuel with new fuel all looks well and cle
heat the spark plug for a few minutes then put back in the engine. sometimes works when you not used engine in a long time. it will take a good few goes to get the old fuel out of the carb, the heat helps burn old fuel.
Jul 09, 2017 | Motorcycles
2005 honda crf150f
i dont think its rev box.(rev box just keeps engine from reving over a certain rpm) could be bad gas or water in gas, also have you checked those valve clearances lately?? 0.003--0.004 on filler gage
May 15, 2010 | 2003 Honda CRF 150 F
2005 honda crf150f
check valve clearances
Mar 27, 2010 | 2003 Honda CRF 150 F
Oil around spark plugs on 1992 honda accord
Yes the oil can cause the car to lose spark, the oil leak could be caused by the valve cover gaskets around the spark openings, but 9 times out of 10 it is the spark plug tube "O" rings. The top of the valve train comes off of the head, the "O" rings are between the two halves, that will fix the oil leak.
Apr 01, 2009 | 1992 Honda Accord
2002 honda civic ex won't start
If a defective spark plug was found, it can destroy the secondary winding in the coil pack for that plug. Change the plug wires too.
Jul 28, 2017 | 2002 Honda Civic
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Electrical Supplies Logo
324 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
