Question about Texas Instruments TI-34II Explorer Plus Calculator
I reset the calculator and now nothing is working
I have exactly the same problem. How many did you reset it ?
Posted on Sep 28, 2010
  • maxodera Sep 28, 2010
    soory, how many time did you reset it ? Because I think, we should only reset it one time, the first time you're using it. For me, I think it was the second time, that is the reason, but I still search a solution for resolving this problem...
Y= button coming up as invalid
well, it could just be that you have some random wrong equation that is, as the calculator is telling you, invalid, press the y= button in the top left of your calculator and scroll down through the equations and if anything is there just hit clear to delete it, one by one, happens to me a lot if i don't put the cover on my calculator. if there is nothing under your y= i would try resetting the ram, and if that doesn't work i would try a factory reset, to get to these options press the 2nd button then the + (should say "mem" in blue above the button) then scroll down to reset and press enter, all the reset options are there.
Aug 29, 2013 | Office Equipment & Supplies
My ti-84 silver edition calculator is not working at all. I have changed the batteries and the back up battery and still nothing but the black checkerboard square is on, it wont even let me turn off the...
If your calculator display the checkered cursor it means that the memory is full and you cannot type in anything. Clear the memory by resetting the calculator.
Press [2nd][Mem] then select [7:Reset]
Under the first Menu RAM select 1:RAM then 2: reset
Nov 06, 2012 | Texas Instruments TI-84 Plus Calculator
All of the sudden it stopt working. Nothing happens when I push the ON button. I changed batteries. I took the backup battery out and put it back in (didn't put new one). Nothing helps. I changed the...
It is sold with an dapator that powers the calculator through the USB port. Use it and you will eliminate any doubt about the batteries. Try resetting the calculator.
Aug 26, 2011 | HP 50g Graphic Calculator
My calculator is typing on its own!!! It's not doing what I need it to do. HELP!!! I have an exams tomorrow. I've tried resetting it several times but nothing is working.
Good day,
Try removing the battery and insert it back.
If this doesn't work, hit the back calculator against your palm gently.
May 24, 2011 | Casio FX-9750GPlus Calculator
I turn on the calculator and all I get is a small black square dot in the upper left corner. TO Connect can read the unit, but nothing works on the display.
If the small black square does not blink The Calculator is Locked
it need an hardware reset
let me know if you if you want to fix the Calculator
ecrdn@yahoo.com
Jack
Oct 21, 2010 | Texas Instruments TI-84 Plus Calculator
When I turn on the TI-84 Plus calculator all I get is a blinkng curser and nothing else works. How can I fix it?
Having received no response in over a month, I assume the suggested reset solved the problem.
Aug 10, 2010 | Texas Instruments TI-84 Plus Calculator
I can't get any keys to work on the calculator
Having received no response in over a month, I assume the reset solved the problem.
Jul 08, 2010 | Texas Instruments TI-83 Plus Calculator
Blank Screen/Won't start up
well the reset method worked for me! just keep trying it...
Nov 06, 2007 | Texas Instruments TI-83 Plus Calculator
My HP won't turn on anymore
I just fixed two "failure to power on" 49g+'s. For the first one I did a moderate slap of the unit against my thigh and then tried a reset (I thought maybe the reset was jammed with some debris) - it worked! The second one just needed me to scrape off some corrosion (an old toothbrush works) from the battery terminals - AJ
Jun 24, 2006 | HP 49g+ Calculator
Texas Instruments TI-34II Explorer Plus Calculator Logo
145 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
