Question about Sharp AR-M450N Copier
Call for service Code: F1-15 Finisher trouble
  • 61 Answers
Use SIM 3-3 to check lift motor. To enter SIM mode press P * C * Is the tray installed so it hits the sensor on the right side? If the tray doesnt hit the sensor it can cause error. To reset machine use SIM 14.
Posted on Sep 02, 2010
5 Suggested Answers
goalie39
  • 469 Answers
SOURCE: finisher trouble, F1-00
F1-00 lost communication with the finisher, check the connection between the copier and the finisher. Shut the machine off, reset the connector then restart the machine.
Posted on May 12, 2009
  • 126 Answers
SOURCE: Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Posted on Jan 28, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Sharp AR-M350N that is throwing a F1-87 Finisher Trouble
IMC PWB communication error
Posted on Jun 12, 2010
hamzaskilltd
  • 316 Answers
SOURCE: sharp arm620u error code F1-88. Finisher is out
IMC PWB communication trouble
How to change settings to tell Sharp MX2300 that it no longer has a finisher/stapler unit.
Does it show the finisher onscreen? or are we just talking about when printing to it.
once you unplug the wire harness for the finished and power cycle the machine using the main power switch it should no longer display a finisher on the screen.
You need to change the configuration of the print drivers on your computer to remove finishing options when printing. right click on the copier in your devices and printers and go to printer properties. Go to the configuration tab, and click the button for auto configure. some little fingers will pop up and tell you what to select click ok and then apply.
Let me know if you are still having problems
Jan 28, 2015 | Sharp MX-2300N Color Copier
Why do i get a error code c1105 on my bizhub c554e and how do i fix it
Sorry your having trouble. Your code suggest you have an optional KM FS-534-535 finisher attached to your copier. The code is triggered by an internal part within the finisher and should be thoroughly inspected only by a certified factory trained service technician. I would suggest you contact your local repair company.
Attempting to resolve this issue on your own could produce negative results.
May 31, 2014 | Konica Minolta Bizhub 222 Black and White...
SHARP ARM 350 ERROR CODE F1 15 FINISHER NOT OPERATING
Finisher lift up motor trouble, look for any mechanical problems in the output tray then cancel the error by pressing #*c* respectively then again press 14 and exicute the trouble cancel this mayt resolve your problem otherwise your lift up motor or finisher controle pwb needs replacement
May 05, 2011 | Sharp Office Equipment & Supplies
IM3511 error code F1-15?? What do we do?
Content Finisher lift-up motor trouble
Details The finisher lift-up motor does not reach
the specified position.
Cause Lift-up motor abnormality
Lift-up motor upper limit sensor
abnormality
Finisher PWB abnormality
Check
and
remedy
Use SIM 3-3-5 to check the lift-up motor
Jul 06, 2010 | Sharp AR-M205 Copier
I am assuming you have a finisher attached to the left side of the machine as this code deals with the finisher. Specifically the C1183 code means there is a problem with the elevator lift motor. Check the trays on the finisher and make sure they are fully inserted in the finisher. Turn the machine off then back on again. If the code returns you will need to contact a service company as there is a drive problem in the finisher.
Good Luck and Thank You for using Fixya.
Jun 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
I have a Sharp AR 407 copy machine and when I turn it on it displays an F1-11 error code. Please help me. I work for a nonprofit and we really can't afford to pay someone to fix it. Thank you!
The problem is in your finisher and the quickest solution to get your copier running is to unplug the finisher and move it away from the copier. Take a tray off the finisher and put it on the copier where the paper comes out. (If the paper comes out too slow and causes a misfeed the tension springs need to be put back on over the exit rollers in the left door, write if you still have trouble)
The Engrish service manual sayeth:
F1-11: Finisher 1 pusher motor trouble/Finisher 2 boomerang rotation abnormality.
What this doublespeak means is that something is blocking your motor's ability to function when it goes through its' power on self test. First thing you should never do is put anything near, around, or under the finisher. I went on a lot of calls for F1 errors and either unjammed a finisher from the wall or unstuck a toner or paper box from under the tray. Next thing is to open the front door, move the plate from side to side, and look for bits of paper wedged in anywhere. Spray any photoelectric sensor you see with a can of air. And check those squishy orange rollers and see if they're swollen. Could be you have a dead motor, which would be at the rear of the finisher or inside one of the trays. Good luck!!
Jun 18, 2009 | Sharp AR-407 Copier
Copier problem - service code F1-70
F1-70 is communication trouble between the machine and the sorter finisher. Check the cables connecting the copier and the finisher and power off and on machine. Should clear the code. If problem persists, may need a new board.
I would also check the ground between the copier and finisher.
Don't forget to rate your answers, please!
May 17, 2008 | Sharp AR-C160 Color Copier
Sharp AR-M450N Copier Logo
1,787 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
