Question about Vizio P2 42 in. HD-Ready Plasma Television
My P42 keeps turning itself off. When I turn it back on, it will turn off again within a couple minutes. I can hear something like a relay clicking on & off several times. Sometimes it stays on for a few hours, other times it shuts off after a couple minutes. IIt's about 3 yrs old. Any suggestions?
  • 1 more comment
  • mnr_lofstedt Sep 02, 2010
    Sounds logical, but I would also like a second opinion if possible.
    Thanks
    How do I remove the back panel? I have a new power supply, but there are so many screws on the back, I need help to know which ones to remove.
    Thank you for the very fast response!
    I purchased another power supply, and will change it out once received. I will let you know how the fix resulted.
    Thanks again.
  • 10,515 Answers
Disconnect the power supply for few minutes, say 30 minutes and then turn ON the TV.This would reset the TV. If you still see the same problem, it confirms a hardware failure.
As you could hear a clicking noise, it is more suggestive of a power supply problem. This a common problem on most of the Vizio's TV. You need to open the TV. Locate the power supply board. You would be able to find blown / bulged / leaked IC's. Take them out and re-solder the new one. ( you could get the caps from radio shack or even from fry's ).
I am pretty sure that it would solve the problem. If the problem still persists, revert and we could troubleshoot further.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 02, 2010
  • taran_2005
    taran_2005 Sep 02, 2010
    Thanks for your response!!
    1.Remove all screws from back of TV panel (yes even the small tiny ones near the bottom)
    2.Remove 4 tiny screws around the input box area
    Lift input box area straight up vertical and it will unseat from the two plugs under it, then remove exposed tiny screws
    3.
    Lift the back metal panel off the TV completely and vacuum dust that
    has collected on it and lay it some where that wont be disturbed.
    4.Take a picture if possible so you reference where screws go and posts go.
    At
    this point you'll freak out for a moment because you can't see the
    board that you need to replace; don't worry, it's hidden under the main
    board that would be right under the input box that we just removed.
    5.Remove back support metal bar by removing two screws left and right.
    6.This
    is where you need to be patient and remove the top main board by
    disconnecting the plugs and screws that are the grounders.
    Note - There could be many screws that you need to remove. This is not an easy job on this model. Be sure that you are aware unless you might damage your TV. If any of the clips broke or board mishandled, you might end up buying a new one. So, kindly make sure to remember the positioning of all the clips, screws and connectors.
    Hope i helped you.
  • taran_2005
    Do update me once you replace the board. You are welcome to ask me any questions later on regarding this problem.
    Hope i helped you.
  • Vizio Master
  • 6,993 Answers
A common problem for this is a bad capacitors on the power supply board. This is why you are hearing the click sound and also turning off. There might also be some other bad component on the power supply board which is making it defective.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Good luck.
Why does my 800 keep going off, then back on again, but itself ?
Try a cleaner/lubricant contact spray. Available @ Radio Shack. Pull out and spray into it, re attach knob and turn in off a number of times. Turn all the way. If problem persist your radio may have a loose wire or solder.
Jan 28, 2015 | Grundig Satellit 800 AM/FM/SW Radio
The fan will not turn on in the unit itself. You can hear power get to the unit. I turned off the breaker and the noise stopped waited a couple minutes and turned it back on and the noise was inside the...
Either the relay is bad on the board or the motor has gone bad...what you are hearing is the transformer in there but it has nothing to do with the motor other then run the relays that turn on the motor...so... it could be a number of different things...relay, motor, or t-stat...you will have to have someone or you use an electrical meter and trace down the problem.
heatman101
Jun 28, 2011 | Heating & Cooling
We had a new oven put in 2 days ago, and the installer turned off the circuit breakers. Ever since he turned it back on my side by side has been making a clicking noise (like a relay). Then it will hum...
Remove the bottom front panel of the fridge and locate the defrost timer. This is a small circular motor with a screw slot in the center. Turn the slot CLOCKWISE ONLY and listen for a click. As soon as you hear the click stop, wait about five minutes and feel the walls of the freezer they should now be cold.If this happens again the timer will need to be replaced. Thank you, Dana
Oct 18, 2009 | Refrigerators
We have a Henry hvr200 keeps turning off
could be overheating, when its cooled down will go again, make sure your filter is cleaned and the hose is not blocked
Sep 29, 2009 | Vacuums
Fridge/Freezer keps turning itself off
Pull the refrig out and remove the back panel . If the fan motor , cooling the compressor is working , then the overload/relay is bad . This is the piece plugged onto the compressor , with 2 or 3 wires attached to it . You can easily replace . If you had given the brand and complete model number , I could have given you the part number .
If the fan is not running , the overload will click off , thereby , causing the compressor to get too hot , making the overload click off .
Sep 27, 2009 | Refrigerators
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
2001 crown vic keeps burning 30A PCM relay fuse
have fuel pump checked i have known a bad fuel pump shorting out causing pcm fuse to blow.
May 10, 2009 | 2001 Ford Crown Victoria
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
RCA P52937SG Will not turn on, only makes clicking sound.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
837 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
