Question about Wasp WWS800 Handheld
I have a WASP WWS-800 C. It automatically ads "enter" after every scan. How can I program it to enter a "tab"?
You have to scan the TAB code from the user manual to "program" the scanner.
Posted on Oct 06, 2010
My barcode scanning set up should be: scan tab scan enter. How can I program it
Hi,The easiest way would be to print out the control code for <tab> <enter> and scan them after you barcode is scanned.
As far as i know its not possible to have two post-emble's and to alternate between the two.
The other and far harder way is to have the text input fields on your program to deliver the correct <tab>, <enter> when you exit the text field.
regards
Dave (Pen Mobile) Germain
Mar 15, 2013 | Symbol LS2208 Handheld
Tip
How To Opening Ports or Adding Allowed Programs with SP2's Firewall
  1. Click on Start / Run
  2. Enter in firewall.cpl
  3. Click on the Exceptions tab
Adding a Port for Internet Access:
  1. Click on the Add Port button
  2. Name it whatever you want
  3. Enter in the ports you want to open
Adding a Program for Internet Access
  1. Click on Add Program... button
  2. A list of all installed programs will be displayed
  3. Highlight the one you want to include for Internet access
  4. Click on the OK button
on Sep 20, 2010 | Computers & Internet
My Wasp wws-800 works while in the docking station but not when removed, suspect li-ion battery but have not been able to find a replacement. Any ideas
your wws800 should have come with two batteries. One goes in the reception base and one goes in the scanner itself. You should allow for four to 6 hours to fully charge. When charged, scan the setup barcode on the bottom of the reception base and then the BASE code. This will allow your scanner to create a connection with the base. Give it 5 secs or so, you should hear three beeps.
Jul 20, 2011 | Wasp WWS800 Handheld
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
How to replace battery for wasp technologies wws-800 scanner
There is a slide on the bottom of the unit, move it to unlock position and slide battery out. Reverse procedure for installing the new one.
Apr 30, 2010 | Wasp WWS800 Handheld
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
My laptop(os windows xp) is infected with iiiiii.exe virus.
first thing to do is try to install and scan your pc with an antivirus program...if you have one already...update your antivirus program. restart your laptop and press F8 to enter safe mode, in safemode, start a full scan.
when finished, reboot back to normal mode then download CCleaner. Scan you laptop using CCleaner to remove the temp files and fix registry issues, you can also disable the startup programs that you do not need to start automatically in CCleaner.
CCleaner
In Addition, you could also install a antispyware program like Ad-Aware just to make sure.
Hope this helps.
Feb 04, 2009 | HP Compaq Presario v3000z Notebook
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Wasp WWS800 Handheld Logo
2,054 people viewed this question
Top Wasp Computers & Internet Experts
Jude24
Andrew Taylor
Andrew Taylor
MaWe
MaWe
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
