Question about Belkin (F5D7230-4) Router (587009)
Forwarding ports on my router
Belkin wireless g router,i have the info,but not sure on how to,port 53 udp as a trigger port,publc port 1023-9999,create another entry port for tcp port 53 trigger,1023-1030 public port tcp ports.this should help me with internet connection
  • Belkin Master
  • 6,487 Answers
I'm really not sure if opening those port will increase your internet connection, because if you have a slow connection you better check it from your ISP. You only need to open port if you're having problem with some application like servers and games.
But you really want to try to opening that port check this link how to do it, this is a sample on how to open port on your router. http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
Posted on May 10, 2008
Need 2 open NAT
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called "opening ports" or "port forwarding."
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
For Belkin router follow this steps
Configuring port forwarding
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in http://192.168.2.1
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Disable Firwall
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 10, 2011 | Belkin (F5D8231-4) Wireless Router...
I need to change my nat settings in order to use my xbox live
I know exactly what you're going through
Give the router's Customer service a call.
Then tell them you need to do Port Forwarding for Xbox Live
On my Belkin I had to do the same thing, but i also set the xbox to run on a separate I.P address, and then turned the firewall off on that I.P specifically.
The ports should be :
* TCP 80
* UDP 88
* UDP 3074
* TCP 3074
* UDP 53
* TCP 53
If that doesnt work it may be your bandwidth. I have been having issues with my wireless on Live because of having too many things running. Try unplugging the ethernet from some things in your home, or turning off the wireless on your laptops before doing this, just to make sure that's really what's wrong.
Good luck, and happy gaming.
Xbox Live GT - SOGGYxBREAD
Dec 16, 2010 | Zyxel P660HW-D1 Router
NAT is not open
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
I need to get an open nat for xbox live...i have a mac
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Aug 24, 2010 | Arris SURFboard SBG900 Wireless Router...
I have a Westell Versalink 327W with a strict nat and I want to open it up for Xbox Live. I have tried port forwarding but that only bumps it down to moderate not open. What should I do?
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
May 19, 2010 | Westell Wirespeed VersaLink...
Belkin + xbox live problems
It's not the MTU problem any more. Its the router's firewall. To resolve it, you two steps to try. First, try to do port forwarding, you must forward the port for XBOX Live to the router's admin page. I believe the ports are 3074 TCP and UDP, 53 TCP and UDP, 88 TCP and UDP. If that doesn't work, try to just disable the router's firewall itself. One of these steps will surely fix your problem
May 06, 2009 | Computers & Internet
How do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
Mar 31, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
I need to open some ports on my belkin UDP88,UDP3074,TCP3074
First of all I would check and see if you router is on the compatibility list from Microsoft. If it is there is a good chance it should work just by enabling UPnP (Universal Plug and Play) is enabled on the router.
If this is not an option, or you router is not on the list you may have to enable the port forwards, they are sometimes listed as NAT or Network Address Translations on the router.
You may have to forward all of these ports:
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
Page 64 of you manual will tell you how to do this. Belkin calls it "Virtual Servers" and it will be found under "Firewall" on the menu tree on the left of the web gui.
Once you're there it should be fairly self explanatory.
Hope to see you online soon!
Mar 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to change NAT type on sierra wireless 595u aircard?
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Feb 15, 2009 | Belkin N1 Vision Wireless-N Wireless...
I have a USR 5461 router and would like to change my NAT to open for Xbox live. How do i do this?
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Jan 18, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Belkin (F5D7230-4) Router (587009) Logo
419 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
