Question about Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN
Shower Aqua Brass unit with one handle not getting hot water to shower head with cold water there is no problem - any idea what could be a problem?
2 Suggested Answers
  • 4 Answers
SOURCE: 8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Posted on Jan 19, 2011
We need to replace the 4 way valve for our bath tub/shower faucets. Parts from the schematic "101 - CENTRALE 4 VIE C/PROLUNGA CM.4" (Rubinetteria "SIMBOLO" Aqua Brass faucets
take the details along to a plumber supply shop ( not a hardware shop or mart) and there will be some one there that will be able to advise on parts , problems or replacement equipment
Dec 11, 2015 | Aqua Brass Home
All the faucets except my shower have hot water why doesn't my shower have hot water
your video doesn't show much of your shower for very long, but at a guess i'd say you have separate hot cold taps, in which case always turn on hot first then carefully turn on cold to ensure there's no issue with water pressure. if there no hot water running at all the hot water valve is faulty
Feb 07, 2013 | Home
No water coming out of spout even though water enters system up to and beyond distribution valve.
this may sound stupid but i resently installed one and if then water pressure was not balanced between the hot and cold the unit would not work
Oct 30, 2011 | Aqua Brass Single lever faucet AQUA BRASS...
My volume control handle takes several rotations before shower finally stops dripping. Do I need a new handle and how would I replace it?
The splines are probably striped and the handle will need replacing. but it may be as simple as the handle set screw is lose.
http://www.aquabrass.com/sections/shower
Nine out of ten times these handles go bad when they get lose so if you buy a new one it will come with instillation instructions.
Jan 30, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Shower has only hot water
its either piped wrong or it plugged up , turn the water off too that shower and take the faucet apart and clean it!!
Feb 18, 2010 | B&K Mueller/B & K 450-032 90 Red Brass...
Water leaking from under my Aqua Brass hot water handle
There's a little set screw that u have to take out with an allen key. then after u take the handle off u have to unscrew the cartridge and take it out and replace with a new one. they're made out of plastic- they break easily.
Jan 04, 2010 | Plumbing
Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN Logo
69 people viewed this question
Top Aqua Brass Home Experts
john h
Tom Chichester
Are you an Aqua Brass Home Expert? Answer questions, earn points and help others
