Question about Compaq Computers & Internet
Needing some suggestions
My hard drive will not read any disc
    Champion:
  • 208 Answers
Follow the ms kb for upper filter lower filter removal.
or get filtercheck 4.6 to remove filters
Posted on Jun 01, 2008
Refer Acer m3970 Can not Install windows 7 of new hard drive
Factory back-up discs and recovery discs are intended to repair defective installations or to kick-start an installation that refuses to start so it is unsurprising they will only go so far.
Your system disc might be defective. This is a problem I have had with XP in the past. It is possible your CD/DVD drive has a dusty lens and is unable to read the disc properly or perhaps the new hard drive has a problem.
I suggest you instal the new hard drive as a slave in another computer and format it and run the chkdsk utility. If all is well reinstal in your computer.
Take a close look at your system disc checking for flaws and perhaps put a lens cleaning disc in your CD/DVD reader before trying again.
Oct 27, 2016 | Seagate Computers & Internet
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
My xbox is having troubles reading discs. It will sometime read a game as a dvd or even a cd, but wont go farther than a set screen. I have no red rings and have cleared my cache in memory settings. Dont...
You have a dirty laser or bad laser easy way to tell is to take your 360 apart and take the disc drive apart with the disc drive apart hook it back up to the 360 make sure to put the bottom shell back on the disc drive so you dont ground it out on the console. Look at your laser while it tries to read games. IF it produces a red beam try wiping it off with a qtip and rubbing alchol if that doesnt work you need a new laser which cost less then $10 on ebay. Hope this helps.
Nov 29, 2010 | Microsoft Xbox 360 Console
I have installed a new hard drive in my Sony Vaio PCG-K35. I want to install the OS but the dvd drive is not reading the disc. The light stays on and does not flicker as it does when reading data. Is the...
Hi there if its only a DVDS player then you can't access CD on there. But if its DVD & CD both player then there is a chance of drive damage. I suggest you install NERO cd/dvd reader software after thsat use those CD or dvd. Thanks
Mar 21, 2010 | Sony VAIO PCG-K35 Notebook
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
Aug 13, 2009 | Acer America Co - Aspire Desktop 4GB 640GB...
My PS3 won't read the games or DVD's. Is the hard drive frozen or broken? My Son is very diappointed that he will lose all his game history? Can anyone help?
if the ps3 wont read DISC games the BD drive in the ps3 is bad and needs to be replaced. I would suggest you call Sony and have them replace the drive if the ps3 is still under warranty.
since the BD discs are read only and nothing is stored on them like game saves, your son wont lose any saves he has becasue they are stored on the ps3 hard drive.
i would suggest if you do send the console to sony i would back up the contents of the drive just incase they decide to wipe it clean.
you can perform a backup from the setting menus on the ps3.
May 31, 2009 | Sony Playstation 3 (PS3) Console
PS3 Hard drive/Disc not reading
you can use the internet browser on the ps3 and find the pics in like photobucket or tiny pic and just save it from the web to your ps3.
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Unplayable disc support
Ive Answered A question Exactly Likethis..
So whats causing this problem eh?
Well this problem is down and due to your Xbox360 Because the Pressure magnet inside your Hard drive is Sticking to the game <-- basically the magnet is a holder inside your hard drive a little handy device that makes your game not fall so its Rumaging around in your Hard Drive Loose Thats why when people KNOCK down there Xbox360's when there up and ON with a DISC inside. Thats how they get SCRATCHED.
What tools do i need to fix this problem?? Read below.
You Need EITHER : A Credit Card
A Peice of strong Paper i.e thin card board
A Xboxlive Subscription Card
Either one of those things to do the job.
Step 1. Make sure THERE IS a disc inside your Hard Drive And Keep the DISC TRAY CLOSED.
Step 2. Point the Card Infront of your Disc Tray And Move it to the Left and Put it in the Gap. and Move it to the left and right abit. Basically Wiggle it about inside your Xbox. ** This Does Not Void Warrenty , Cause Disc Failure , Or Scratch Discs. **
Anything that does Break will be your own fault for not following Instructions.
Step 3. Once inside and you've wiggled it about for 2 - 3 minutes... It will Unloose the Magnet Causing your game to come undone and then you " EJECT THE GAME " I repeat " EJECT THE GAME " from the DISC Tray. and Place it back in. and start up the game and then it should get past Loading Screen etc. and Be fixed.
Now I cannot guarentie that this will stay like this for along time. so I suggest you get your Xbox Fixed VIA Warrenty If you still have 1year. if you Foolish People Brought yours off Ebay then I have a solution too.
Pop down to GAME and Sign up for there Unlimited Warrenty xbox360 for £50 - £60 a Month. or Year i carnt remember. It might be a year.
And Theyfix it for you.
And I suggest you ALL DO THE SAME! :)
Thanks For Reading this Solution. I do Very Hope this has helped you people.
Please Rate me Etc. :) Thanks
Jul 06, 2008 | Microsoft Xbox 360 Console
Won't read disc in hard drive
yes you do need to get the drive cleaned you can get a laser disk that cleans it from either game or playstation or maybe online they usually work
Jul 17, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
21 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
