Question about Dell Dimension 8200 PC Desktop
I get dell from my friend it has no sound,no ethernet ,its windows xp i adjust sound from controll panell the message no mixture drive
    Problem Solver:
  • 4 Answers
Go to devise manager and unistall the sound card
Reboot computer and it will find the devise and load the drivers
If no sound after this try another sound card
Posted on Nov 14, 2010
No audio, no ethernet
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
May 19, 2011 | Intel 865G Motherboard
Dell drivers do not work on new windows xp pro.
C drive will show at least 2 partions; one will be about 32mb in size;others will be larger...install windows on one of larger partions; go to dell.com/drivers and download in proper order drivers for your version of windows onto same HDD as windows...if a driver file is not on drive, dell with ask if you want to create one;YES
Mar 20, 2010 | Dell Dimension 3100 PC Desktop
I have a dell dimension 2400 with XP Home. I haven't used it for some time and I updated all my apps and Windows.Then updated the drivers but the only ones that worked were the Intel universal host...
Ok, instead of having all the hassle, my best advise for you is this, have your hard drive reformat, install it first with windows xp SP1 then upgrade it to windows xp SP2, in this way all the drivers missing and not supported will be rsetored, windows xp supported almost all drivers
Nov 15, 2009 | Dell Computers & Internet
My drive crashed so i installed a new hard drive, and used the disks provided to install windows xp,and drivers, but I'm noticing that the following drivers did not install, the base system device,...
Try to manually update the drivers.
Go to Settings/Control Panel/System
Hardware tab
Then Device Manager
Click on one and update.
Let the OS search the CD with the drivers.
(You may have to navigate to the correct directory)
If this fails you will have to go to the DELL website and download the drivers for your machine.
Hope this helps!
Oct 31, 2009 | Dell Inspiron E1505 Notebook
I have a Dell Dimension 2400 with windows xp. I was having some problems and decided to reinstall xp. After the install, my resolution was set at 480 x 640, everything was big on the screen so I went into...
install windows xp after that open link and download driver and install driver and enjoy .....
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_CEL_2400
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
Ethernet Controller is missing
You are unable to use the Ethernet, VGA etc. because you have not installed the drivers for the same.
You might have received a Drivers CD(it will read "Drivers and Utilities") which will be in blue color, when you got the computer from Dell.
In case if you haven't received it you can contact Dell on 1-800-624-9897 and request for a Driver CD. I guess this Dimension model is @ End of Life (I mean no more produced by dell) you might have to download the drivers from Dell's support site (www.support.dell.com) you will have to get it downloaded on a different computer and copy on a CD or a Flash drive.
Once you got all the drivers. First extract them in a separate folder
Go to Device manager
Right click on the Ethernet controller (where you see a yellow exclamation)
Click update drivers
Show the path where you have the driver files
Sep 20, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No Audio Device
hmm strange.. sounds like plug n play service issue or a bad xp install. with dells usualy u have to install 1st desktop system software then chipset then audio, video, ethernet.
Oct 05, 2008 | Dell Dimension 3000 PC Desktop
Ethernet Controller
I had to reinstall XP like 6 months ago, on a dimensions 3000. just reinstall the drivers. here i think this is all of the drivers.
just start "Dell Driver Reset Tool.EXE"
and run "Sownd driver for 3000.EXE"
driver for vga "Intel(R) 82865G Graphics Controller.exe"
and the Ethernet driver "Intel PRO100 VE Network Connection.exe"
Click Here for a zip of all the drivers.
Feb 05, 2008 | Dell Dimension 3000 PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 8200 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
