Question about Panasonic DP-3030 Grayscale Copier
How to change paper size and orientation in paper tray
I want to change papar orientation from landscape to portrait. I changed it in paper tray but paper orientation in printing does not changed. plz guide.
Dude, changing paper orientation on paper tray is just one step, while you must change paper setting on printer driver too. In some machines, you should change paper switch position too :)
Sep 30, 2013 | Toshiba EStudio 223 Copiers
Ricoh Aficio MP C3300
Go into the print driver and the machine settings and make sure the paper size and direction are all in agreement with each out and the paper in the tray itself. If screen icons do not agree with the size and direction of the paper in the tray you will have a lot of weird problems.
Jul 22, 2017 | Ricoh Office Equipment & Supplies
Tray 1 has defaulted to a landscape orientation--cannot find a way to redirect it to portrait. NOT an issue with placement of paper to be copied.
There's a dial on the front right corner on each paper tray that tells the copier which paper size is loaded in that tray. In the case of letter size paper it also indicates orientation. If the short edge is facing the front of the copier the dial should be on LTR, if the 11" edge is closest to the front the dial should be set on LTRR.
Aug 25, 2011 | Canon imageRUNNER 4570 Copier
Non stop papper jam what we do?
My first idea would be to clean the feed roll . I am not sure what more to tell you right now without knowing where it is jaming.
You may also want to confirm that the machine is displaying the proper paper size and proper orientation in the paper tray. Often times if the paper is stopping, without the paper being damaged, the tray settings are incorrect. Look on the machine display and confirm the proper paper size and orientation. Those trays flex a lot and that simply may be your problem.
Feb 19, 2011 | Xerox CopyCentre C118 Copier
No matter how i place the original on the glass, or even whether i use auto-feed, the copy is oriented landscape. How can i default it back to portrait?
Hi Anthony,
This is one of those "oh ****" moments.Please take a look at the orientation of the paper in the paper trays. Please open both paper trays,(you may have 4 trays, with the option of a 5th large large tray) and please carefully look at the orientation of the paper. I will use the terms that "some" folks use(and it is helpful) to describe the paper orientation. There is "long edge feed" and "short edge feed" I prefer landscape and portrait as you do.Now, the most likley problem you have is that the "DIAL" for paper size (located at the front right of the PAPER TRAY itself ) is set incorrectly.You will have many settings available to you thru this "BLUE DIAL" . The copier trusts that you have looked at the orientation of the paper and therefore set the dial appropriately. If there is a "mismatch", you can have paper jams or image problems. I bet you a dollar this is problem.The dials say one thing, and the paper is set differently. Happy new year!. Give me a pat on the back @ FIXYA if I helped please.If I didnt help you, I am very sorry.
Jan 18, 2011 | Canon ImageRunner 3025 Black and White...
For some reason our Canon Image Runner 2270 started printing in landscape versus portrait. We did not touch the machine and the printer setup shows portrait - I assume I have to change something on the...
Check your paper size/orientation dial on the paper tray you are using. I believe this machine uses this dial to tell the machine what paper size and orientation is loaded. Make sure the dial matches the size and direction.
Aug 20, 2010 | Canon imageRUNNER 2200
Hi i have problems with my 7502 gestetner nrg photocopier
This sounds like a paper size issue. Check your papersize and oriontation in the tray(green selector font right or back left of tray) and check paper settings under the user tools menu for tray 1. let me know if that works, so we can trouble shoot.
Feb 23, 2009 | Gestetner DSm618 All-In-One Printer
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Panasonic DP-3030 Grayscale Copier Logo
50 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
