Question about RCA Universal Remote Control
RCA systemlink 3 remote
I have a remote with a code search button on it but I can't get it to reset to my tv. I have pressed the enter button when it flashes, I have hit the tv, enter button, the on/off button....
Can you help??
    Genius:
  • RCA Master
  • 1,550 Answers
My friend you gotta turn on manually your tv first.Then push and hold until the indicator light lights,then release the code search button now push and release the Tv button after that you gotta push and release the power button until the Tv turns off then you push the enter button to save the code.Good luck.
Posted on May 11, 2008
  • Nocrala Feb 05, 2011
    Ah, I've been having the same problem as Dakatalee for quite a while. It worked!! Thank you, The Witch.
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
Re: need codes for rca remote Systemlink 3 for 22729 tv
Katina, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.remotecodelist.com/remotes/rca/rca_systemlink_prog.html
RCA universal remote code lists RCU Series Systemlink series direcTutor
Electro help RCA SYSTEMLINK 3 UNIVERSAL REMOTE TV SETUP CODE LIST SETUP...
Aug 19, 2016 | RCA Televison & Video
I have an RCA system link4 remote but it won't operate my MAGNAVOX tv. have any advice?
http://www.ehow.com/how_5932125_program-rca-systemlink-remote-control.html?ref=Track2&utm_source=ask
http://www.google.co.in/#sclient=psy-ab&hl=en&source=hp&q=rca+systemlink+4+codes&pbx=1&oq=rca+system&aq=2&aqi=g4&aql=1&gs_sm=c&gs_upl=0l0l6l594l0l0l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=3cc78a7dcc01c3c&biw=1024&bih=527
so far i didn't try to solve this kind of problems practically as no customer approached me with this type of problems in my place (bangalore) ...... so sir i can't tell exact procedure ( short root ) ...... so i have given two links which may solve your problem ...... check first link & see whether you have followed same procedure ...... second link also may help you .............. but little time has to be spent .........
Oct 27, 2011 | Televison & Video
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
Do not know how to program the systemlink3 universal t,v. remote control to my t.v.
Option 1:
To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE***Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Option 2:
Thanks for the hints on your web site. For the RCA SystemLink 3 with the key pad, I could not get the sequences described to work. But they did point me in a direction which worked for my remote:
  • With the TV on (for TV)
  • Press and hold code search until the light stays on
  • Press TV (for TV) button once
  • Press the on/off button once
  • Thereafter, the light will stay lit and every couple to three seconds it will blink twice indicating it is trying another code.
  • When the TV turned off, I pressed enter. Thereafter the unit worked.
May 04, 2011 | RCA Televison & Video
I need code for coby tv-1360, to work with rca systemlink 4
Hello
There is no code for your Coby with RCA systemlink-4 specified. But you can find the stored coed in Coby with RCA remote. Here is the proceedings. Do it and check.
Press and Hold CODE SEARCH button until ALL FOUR device choice buttons light up.
These FOUR buttons DO light up, they are on the SECOND ROW from the top; and from LEFT to RIGHT are named:
SAT-AUX CABLE VCR TV
After ALL FOUR are lit, RELEASE the CODE SEARCH button. All four lights will stay lit!
Select the device you want to control. Press that button ONCE!
The light will stay on for the selected device, the other lights will turn off. Press the OFF-ON button repeatedly until device powers up or down. If device is off and this turns it ON, try channel up or down. If device is turned ON and this turns it OFF, press ENTER and try to turn it on.
If this does NOT work, you don't have the correct code. Go through all the previous steps from the beginning. I actually counted the number of times I depressed the OFF-ON switch, and this helped immenssely! For example, the TV turned Off or On after 19, 45, 76, 94, 115 and 164 depressions of the OFF-ON button.
Of course it wasn't until I hit the 164 mark that it controlled all functions, and is now going great! But I knew NOT to **** around with a number I had all ready tried, and which didn't do the trick the first time!
Remember, when you start from the beginning, it's just that, from the beginning! You'll notice the device turns on or off after the same amount of depressions of the OFF-ON button, but that may not be the code you need.
Again, this is for an RCA SystemLink 4 Remote Control only, NOT for any other model!!
[2]
Without codes:
  1. Turn on TV.
  5. Press ENTER.
[3]
With codes:
  1. Turn on TV.
  5. Press ENTER.
Mar 02, 2011 | Coby Televison & Video
I have an RCA systemlink 6 AV remote control, and a digix DVD player. How do I set up so the remote with work for the dvd player?! Or I have a cox digital remote.
  1. Turn on TV
  2. Press and hold CODE SEARCH until light stays on, release.
  3. Press TV button.
  4. Press ON-OFF repeatedly until TV turns off.
  5. Press ENTER.
    (Repeat for other devices.)
Sep 21, 2010 | Digix HT1056A DVD
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Nov 19, 2008 | RCA 3-Device Universal Remote with...
Code to use with my tv and how to punch it in
the rca systemlink 4 is very good
toshiba code 105,162,160,161,049,072,109.118 one of these should work
press code search
press tv
enter code press on/off
tv will come on
Nov 11, 2008 | RCA Universal Remote Control
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
8. Try the code search method If there is no more code left to try.
Dec 16, 2007 | Televison & Video
Televison & Video Logo
344 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
