Question about Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive
Seagate P/N 9SF2A4-500 doesn't work with Windows 7. Works ok whith XP. Fat32 formatted. What to do?
  • kai_wolkesso Sep 02, 2010
    Can't reach it over USB, doesn't recognize it at all.
  • Seagate Master
  • 27,725 Answers
Try formatting with NTFS
hope this helps
Posted on Sep 02, 2010
  • Brian Sullivan
    Brian Sullivan Sep 03, 2010
    try installing some windows7 drivers it has different drivers than xp
Windows 7 pc will not play cd made on older pc
You can tell any program in Windows 7 to run in Windows98 compatible mode. The standard format on windows2000 was fat32 Windows7 should run it but try to right click on the opening program and run it in 98 compatible mode. If not then XP mode Windows XP would run in either format fat32 or NTFS.
Apr 19, 2014 | Acer Computers & Internet
Seagate desktop expansion Xbox 360 hard drive format problem
Should work. Xbox uses FAT32, the same as Windows XP, Vista, 7 and 8 can all read it. When plugged into the computer can you see the disk in Disk Management?
Right Click Computer > Manage > Disk Mangement
Jan 29, 2013 | Seagate Computers & Internet
I need to replace the (failed) HD with a Seagate 80GB which is currently formatted FAT32. Is this OK or do I need to reformat as NTFS? Using WinXP
I'd use NTFS but you can make up your own mind here....
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/choosing_between_ntfs_fat_and_fat32.mspx?mfr=true
If you have old computers that need to access files on yours go FAT or FAT32. If you intend to or would like to add huge hard drives in the future (over 2 TB) go NTFS.
Regards
TickMagnet
Aug 19, 2011 | Dell Dimension 2400 PC Desktop
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
Jul 17, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
I wish to use the seagate hardrive to back up music on a brennan jb7 i am having problems formatting the seagate to fat32
Im not sure why you want Fat32 but with that old file system a partitition cant be larger than 32GB otherwise it wont let you format with Fat32. You can create as many partitions as you like maybe have some Fat32 and some NTFS if you like. Just typy in disk management where you normally do a search or run with XP and that will let you organise all of your partitions. Cheers and please vote
May 17, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot complete full format, it take more than 8 hr and at 99 % complete it stops and says "format not complete" , (it works when doing quick format but iam unable to use the drive on my ps3, and...
Welcome to Fixya. If you want to use the drive to your PS3 Console you can still do a Quick Format on the Hard Drive but make sure you select Fat32 File System type to be able for the Ps3 to detect the hard drive. Make sure you use Windows XP or Windows 7 on formatting the hard drive to Fat32 because Windows Vista dont have Fat32 it uses ExFat.
Thanks for using Fixya.
Mar 04, 2011 | SmartDisk FireLite 80 GB Hard Drive
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
My seagate st3250820a has been setup in old pc in dos fat32 mode using device driver and running ok before..now i put my harddisk into new pc has detected 137 mb..can you pls to inform how i fix it to 250...
Please format the disk. You will get the disk space back. If your new pc is running windows NT, 2000, XP, or Vista, while formatting keep the file system NTFS.
Dec 13, 2010 | Seagate Computers & Internet
Windows 7 on slave drive, can I format master now?
in your bios can you tell it what drive to boot from first. sorry for the lame question but im thinking its going to the defualt drive each time.
Nov 30, 2009 | Microsoft Windows XP Professional
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Seagate 160GB 3.5" External USB Drive 160 GB Hard Drive Logo
1,557 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
