Question about Video Game Consoles & Games
Rocketfish hdmi no sound
I have a rocketfish hdmi cable for my playstation 3 to my tv, it was working fine until yesterday now i have a great picture but no sound. how can i fix this?
  • djfer Apr 04, 2009
    I have a mac G5 power pc. My new Rocketfish webcam gets Skype video right out of gate, but no audio. Any fixes for this?
  • Aaron
    Aaron May 11, 2010
    For those of you experiencing the same problem as Ryanmca, it's also quite possible that you may be experiencing an HDCP handshake issue or may simply need to verify your audio output settings. HDCP handshake issues can generally be resolved by power cycling the connected devices (turning them off and on again), but for specific instructions on how to verify your PS3's audio output settings you'll want to refer to your owner's manual documentation or Answer ID #262 in the knowledge center database on PlayStation.com.http://www.us.playstation.com/support/ps... For those of you experiencing the same problem as djfer, there is a setting within Skype that you may need to adjust for your Rocketfish web camera's microphone to function properly: 1) Open the Skype program and click "Tools," "Options," and then "Sound Devices." 2) Uncheck the "Enable automating sound device" setting adjustment box. I hope this helps you out!
Have you tried another cable? Try this one from Amazon:
http://www.amazon.com/Eforcity-Meter-HDMI-M-Cable/dp/B000E8OVMQ/ref=pd_bbs_sr_3?ie=UTF8&s=electronics&qid=1210442074&sr=8-3
For future reference there is no difference between a 70$ hdmi cable and a 5$ one unless you are going through walls or over 25 feet.
Posted on May 10, 2008
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
I have a Sony playstation 3 that I use as my dvd player and run it through my yamaha via an HDMI cable. I also connect the Yamaha output to the TV through an HDMI cable. Until recently the playstation...
Look in the manual for which version of HDMI. If it's 1.2a, they had a problem with the boards and were repairing them. Contact Yamaha @ 1-800-292-2982 Hope this helps
Jun 11, 2010 | Yamaha RX-V863 Receiver
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
May 18, 2009 | Televison & Video
I have been playing my playstation 3 on a regular Hd tv and it worked fine but now it wont connect to my Protron (HDMI) tv with my HDMI cable.
you have to reset the video setting and it will work again Hdmi is different on each tv so you have set this up again ok let's do this with the unit off turn the main switch on the back of the unit connect your Hdmi cable to your tv now place your finger on the front on/off switch keep your finger there ok now turn the mainswitch on the back of the unit the playstation turns on but don't remove your finget yet wait about 4 seconds or until your heard another bip (not the one when the playstation turns on) once you heard this bip remove your finger before the playstation turns off if you let it turn off try again all of this but if you remove your finger on time just wait few more seconds and bingo you have picture again using Hdmi
Mar 10, 2009 | Sony PlayStation® 3 (80GB) Console
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Problem
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
353 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
