Question about Yamaha DVR-S150 DVD Player
When attempting to play a DVD the DVD player starts and stops for a while, almost like there is a scratch in multiple areas of the disc. This continues for a while until it freezes completely. This problem occurred quit some time ago when the cupboard door was shut and it appeared to overheat. After cooling off the problem resolved. This time is has not overheated and the problem doesn't resolve
  • Yamaha Master
  • 11,800 Answers
The laser lens is full of dust. For best results open the unit, blow away the dust under the lens with a can of compressed air and finally wipe it gently with a q-tip.
Posted on Sep 02, 2010
  • hdridr81 Jan 23, 2011
    How do you open the DVR-S150 to "blow away the dust under the lens with a can of compressed air and finally wipe it gently with a q-tip.". Anyone know of a service manual online somewhere? Haven't been able to find one and this unit is more difficult to open than my daughter's Toshiba Laptop when I repaired a broken power-supply connection several months ago.
  • Azrael SRL Jan 23, 2011
    http://kxtga.com/ca1ahadvr81506mrvicm28u...
Still works very well but recently some disks just suddenly stop playing. What could be the reason?
Dirty laser.. scratches on discs..and sometimes laser diodes get weak and then will have issues playing discs. Some NEWER discs are a different format and the player will need a firmware update (connect to internet via Ethernet cable to get updates)
Apr 13, 2015 | Televison & Video
Dvd player will not play dvd disc keeps saying cannot execute command
Some DVD players may display a Check Disc error.
Use a soft cloth to clean the disc; the disc may have fingerprints or smudges.
Examine the disc for any cracks or scratches that might be interfering with playback.
If attempting to play a DVD-R, DVD-RW or other recordable DVD format, make sure the disc format is compatible with the DVD player. For more details
Professional Quality Bulk DVD Replication Services Scotland UK...
Jan 12, 2014 | Element Electronics EDBCO11 Blu-Ray Player
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
Picture skips, flickers, cannot watch. Was working for 10 minutes, then started. Stopped and started, tried different DVDs, tried a cleaning DVD, tried using compressed air. Problem still happens. The DVD...
Some of the common causes of this issue can be found below.
  1. Take the disc out of the unit.
    • Verify that the disc is clean and not scratched.
    • If disc does not appear to be clean wipe it with a soft lint free
      cloth.
  2. Try other discs. Verify that they are clean and not scratched.
  3. Unplug the unit for 2-3 minutes.
  4. After plugging the unit back in, try multiple discs to see if they
    work.
  5. If problems persist I would have to say there is something over heating and it cant be fixed or is not worth the cost of fixing
Feb 27, 2011 | Toshiba XD-E500 DVD Player
All of the sudden our Sony DVP-sr200p dvd player is not loading our dvd's, it is stating "cannot read disk". Any solutions?
use soft cloth to clean the disc.
Attempt to play another disc.
If another disc plays in the DVD player, then the previous disc is faulty.
If still the same. try to unplug for 3 hours. if the same. check sony.com/repair for service option
Oct 17, 2010 | Sony DVP-SR200P DVD Player
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
DVV Player won't play disc
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Nov 21, 2008 | Philips DVP3345V/17 DVD Player/VCR
When trying to play DVDs the words unknown disc title appears. Even after several attempts with various DVDs we havent had any success.
have u tried cleaning the hea of ur dvd player?after using a dvd player or cd player for long times of continous play say 6 months or if u play too many scratched discs and u dont clean the head of the player it starts skipping the disc or many a times dosnt recognise the disc so it'll give u errors like "Unknown Disc", "Disk Error" etc so i would really recommend u to clean its head using a dvd head cleaner cd.. its easily available in the video stores or malls.. u can purchase any dvd head cleaner cuz there are number of manufatcures for this. im sure this would solve ur issue.
PLEASE DO RATE ME,WOULD REALLY APPRECIATE IT
THANX
Oct 06, 2008 | Philips Televison & Video
Yamaha DVR-S150 DVD Player Logo
78 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
