Question about Electronics - Others
Card slot won't read p2 card
I have an alienware laptop with a card slot that up until two days ago, I was able to put my Panasonic p2 cards into, and transfer the mxf files onto another hard drive. I was given a mandatory software update from DVFilm on their Raylight mxf to avi conversion software. As part of the update, I had to install the 32-bit driver for all windows os, the panasonic p2 viewer v3.1.2, and the directx 9.0.
Since the update of that software, my pc will no longer recognize the p2 cards. I've tried installing and removing the p2 drivers, new one and old ones, and that hasn't worked. The raylight company has not been any help.
My question: All I need is for my pc to recognize the p2 cards so that I can transfer the mxf files onto another hard drive. Any suggestions?
THANKS for any info!
Joe B.
  • TripSonic Nov 26, 2008
    I have a Dell M6400 with Vista 64-bit on it. I tried to install P2 driver for PCMCIA card reader and this allways times out! So after trying to install driver, my PCMCIA port does nothing anymore!!! The only thing I then can do, is restore to the point before installing P2 drivers...
    Genius:
  • 1,019 Answers
have you thought about restoring your system, to an earlier point.
before the problems occured, with your software update.
also if this fails, or you are unable to acheive this.
check in the device manager, to see if you have any yellow exclamation marks, next to your device.
you may need to re-install the device/driver for your card-reader.
Mike @ compurepair.
Posted on May 11, 2008
SD Card and disc stuck in CD slot of Alienware M14x?
try taking a small piece of wire and bending a small hook into one end slide it in on TOP of the stuck disc and hooking the center hole of the disc, (you don't want to get the wire under the disc because you could damage the disc reading hardware) also once you have the disk hooked you may have to use the tweezers to gently hold the front of the disc up to align with the slot as your pulling it out. you should feel a little resistance but don't try to force the disc out too hard.
Mar 23, 2015 | Dell Alienware M14x Notebook
Alienware area 51 card reader not recognizing 64gb exfat sd card
I would check you have all the latest updates for your Vista installation as I know for some versions of Windows extra updates are necessary for exfat support.
Does the SD card read; is it accessible; in other devices?
Mar 19, 2014 | Alienware PC Systems Alienware Area-51®...
Laptop won't read SD card
have you been tried to use other sd card ? or have you been tried to use other usb slot of the laptop just to know if where the main cause of the problem.
Mar 25, 2013 | Acer Aspire 5736z 4460 Laptop
I have an hp pc with photo card readers. When I insert the sd photo card nothing happens.
Do you have insert it in the right place? For my experience the first time I use my laptop's SD card reader I inserted it to a wrong place. The card reader on you PC may like the card slot of your camera, and there is a false card in it as dust-proof. You should get it out buy press it and then it will pop-up(at first, I dare not use big strength to press it until I know it won't damage it) Good luck if your problem is the same as mine. else ..
Apr 30, 2011 | Panasonic Cameras
I cannot copy the pictures from my Sony Cybershot to my pc; A few days ago my pc crashed and I lost the CD-ROM to install picture package menu. what do to now ?
Hello, you can recover the pictures directly from your camera without needing cables if you have a card reader.
If you do have a card reader, then:
  1. Open your camera's memory slot
  2. Remove memory card
  3. Insert memory card in your PC or laptop's memory card reader.
  4. The card will then appear on My PC exactly like any pendrive.
  5. After you're done copying photos, click over the system tray's "Safely remove Hardware" icon, and select the memory card.
  6. Wait until Windows prompts you that it's safe to remove the hardware.
  7. Put the memory card back on the camera.
Also, from here you can get the drivers for your camera
http://esupport.sony.com/perl/swu-download.pl?upd_id=4598&SMB=YES&template_id=1&region_id=1
And, from here, you can order a new CD from Sony, but they will charge you for it.
https://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
Dec 07, 2010 | Computers & Internet
My computer won't show my sd card on the screen
hello,
the reason your laptop wont show your sd card on the screen is because it is not reading the sd card.
it is not reading the disc either because
1. there may be a problem with the card reader,
2. there may be a problem with the slot on the laptop,
3. there may be a problem with the memory card.
to check if it is the card reader, try to use the same memory card reader with another sd card on another laptop and see if it will read it.
to check if it is the slot on the laptop, try to use a new sd card and a new card reader on the laptop to see if it works, if it does not, then you know where the fault is from.
finally, to test the sd card, try to use it on another laptop to see what happens. if it does not work then you can tell where the fault is from.
whichever the fault is, you can change them.
but if it is the card slot, you will have to open up the laptop and clean the slot carefully.
take care.
Jun 08, 2010 | Computers & Internet
Download file procedure from p2 card to Mac via firewire
Hello!
Since you own Macpro you need to connect a duel adapter for pcmcia cards and since Macpro has already drivers for P2 ,the rest is easy,just connect and follow the procedure.
PS
You can also download through firewire and usb port.
Feb 21, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
Memory card error?
hello catcahill, i recommend that you try another sd card in the slot to see if the card is faulty or the camera.
Jul 09, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Memory card not recognized
Try to put your sd card to the slot, and check device manager.
check if there is yellow question mark on the device manager.
if it is, it's driver problem, just update the driver.
if not, try with another sd card and if this still not working, it's your sd card slot has problem.
Mar 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
Electronics - Others Logo
700 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
