Question about Gestetner Office Equipment & Supplies
We have a Gestetner 5305 CopyPrinter. We are looking for someone to service our copier
Open SKy
  • 620 Answers
SOURCE: ricoh/gestetner
Hola si lo que te esta pidiendo la maquina es que cambies el cilindro y no lo as cambiado tampoco queres cambiarlo tenes que resetearla de la siguiente manera abris la cubierta delantera sobre la derecha por donde va el cil hay una ranura que tenes que poner un destornillador o algo similar prender la maquina y listo se te resetea la maquina creo que es eso probalo y contame cualquier cosa o duda
Posted on Mar 07, 2008
Cogz
  • 1326 Answers
SOURCE: copier problems
What model gestetner is it? There are different ways to rest it. What generation are you talking about? 10 years old or two days old model?? Need some more info. The problem may just needs to be rest, it most likely a fuser code to cold or to hot.
Posted on Mar 11, 2008
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
isaacwoodard
  • 54 Answers
SOURCE: My Gestetner copier # 3225 prints blank pages.
it sounds like you may have a part of the unit that is out of alignment. If everything isn't securely fit back into the machine, it won't image properly.
If it will neither print (if it has the option installed) NOR copy images, NOR will it print a test page from its memory, then the places I would look first would be:
1: The connector on the transfer belt which is the brown, flat thing found on the door of the machine...sometimes the connector is bent and doesn't make good contact, which prevents toner from transfering to the belt from the drum.
2:The drum unit may not be secured well to the back of the machine and the Charge Strip above it may not be in place. I can't recall immediately if it has a grid or just a wire, but the hair thick wire can break, which can cause exactly your problem, though you should be able see the wire easily with a flashlight.
Unfortunately, when the office "Mr. Fixit" tries to remove a jam and save the company an easy 100 bucks it often can cause other problems...I've worked with copiers since 2001 and I'd safely say that at least 1 in 10 routine calls revealed complications from someone unqualified who tried a little too hard to fix the unit.
But check on those two things and if it still doesn't work then let me know and I'll try to help you more. :-)
Posted on Jan 08, 2010
  • 360 Answers
SOURCE: how to enter the service mode ? of the gestetner
hello, press yellow colour button,107 cancel button
Posted on Sep 10, 2010
Copyprinter 5375 why does one of my ink drums not work nto accept master
Consult Authorized Service Center or official Helpline of Manufacturer.
Apr 26, 2014 | Gestetner Office Equipment & Supplies
E22 code
E - 22 Scanner home position sensor error.Possible causes:
scanner home position sensor failure
scanner motor defective
incorrect scanner ddrive wire position
Remove the exposure glass and verify the wire and the sensor actuator.
Turn DIP switch 101 - 1 ON and press START key to run free the scanner.DIP switch is located on PWB board in rear area,remove the rear cover.
Feb 07, 2013 | Gestetner - 5309L CopyPrinter Copier
Looking for some one to work on a gestetner a045 in louisville ky
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 06, 2011 | Gestetner A045 Wide Format Copier
Do You have anyone in the ocala florida area that services gestetner cpoy machines?
Look for a copier dealer or service center that is listed as repairing Ricoh, Savin or Gestetner. They are all the same machines. In other words your Gestetner copier is made by Ricoh and Ricoh Dealers are far more common and easy to find than Gestetner. If you need to know the exact model then just reply with your Gestetner Model number and I can tell you what the Ricoh equivalent number is.
Hope this helps.
WheatlandServices
Dec 08, 2010 | Gestetner Copier
My copy printer can't show a3 paper . how to fix it?
may i know whats the model of your copyprinter?
use an A3 drum.
check if ur using an A3 drum
Jan 25, 2010 | Gestetner Copier
The getsetner drum was left out over night and now is "dry"
may i know whats you copyprinter model?
do some force in simolation to pump ink on to the drum so that master will stick to the drum
Sep 15, 2009 | Gestetner Copier
Oct 27, 2008 | Ricoh Aficio 250 Copier
Where is the plotter cover on the gestetner
The plotter cover is the piece that you press down when installing a new roll of masters. it is located on the top right of the machine.
Sep 04, 2008 | Gestetner - 5309L CopyPrinter Copier
94 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
