My printer can not work properly and the light always light yellow.by the way my print is ip 1980.
    Problem Solver:
  • 13 Answers
I  don't see an error code for yellow but could it be orange? but here is a link that has the error codes and tells you what they could be. there is a app. That you can down load that resets it. called "Resetter".
http://whisnusa.blogspot.com/2009/06/error-code-canon-ip1200-ip1300-ip1700.html
Posted on Sep 02, 2010
Canon ip 7240 i used refill ciss but 4 flash
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. When a printer flashes 4 times this is a sign that an ink tank is not installed correctly or that the cartridge will need to be replaced as it is low on ink. As you are using a CISS the cartridges will always have ink in them. To bypass this error all you will need to do is press and hold the RESUME button on the printer for 10 seconds and this will turn off the cartridges ink status monitor and allow you to continue printing.
Canon Error Codes
I hope I was of help to you
Oct 30, 2013 | Office Equipment & Supplies
Canon ip 1980 printer does not print the paragraph. it prints nothing, its like printing invisible letters or uses white ink.
sounds like you are out of ink or the cartridge(s) need cleaning. Go to "printer properties" then "maintenance" and click "cleaning" or "deep cleaning". Then print a "nozzle check" to see if it worked. If it improves, repeat until 100%. If not, get a new cartridge.
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Canon Office Equipment & Supplies
My printer is canon pixma ip 1980, its orange light is blinking 7 times, it says the cartridge is not installed properly (but i did not even touch the cartridge), how can fix the problem? pls help, i need...
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Canon PIXMA iP1800 InkJet Printer
Canon ip 1980 offline problem
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
May 31, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer will not print red
remove color cartridge and use IP solution to clean the printer head properly and dry atleast 5 min and put the saem in the particular printer after this done also problem is occur do the refill of yellow & red colors then this will be resolved..... satish, software developer...srikakulam
Feb 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Install
ok first u go to the google and write the canon ip 1980 printer driver and after install the driver and run this folder.. after install the driver printer working ok
Apr 01, 2009 | Office Equipment & Supplies
I have a cannon i9900, it has always worked perfectly. For the past week I can not print anything. I reinstalled software today still down, I see one green light followed by 5 yellow flashes (keeps...
Dear Bill,
Flashing 5 times in orange indicates that print head error occurs so it cannot be detected properly by the printer. To make it sure, install a good print head in the printer. Is the problem fixed?. If the problem still persist, carriage part may be faulty. Overall, the print head is the most faulty part in this case. So, you need to replace the print head with new one.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Cannon Office Equipment & Supplies
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
59 people viewed this question
jasbo
jasbo
