Question about Dell Latitude D800 Notebook
The mouse pad and small mouse in the middle of the key board is messed up, how can I disable it?
  • 41 Answers
On top of the keyboard there will be a button turn it off the tuchpad will be disabled. Or if not then go to device manager under Mice Another Pointing Devices look for the mouse right click on it and then disable. Issue fixed ..
Posted on Sep 03, 2010
Small red light that disables mouse pad
I think you have the Touch Pad disabled. You can toggle the touch pad between enable and disable by a couple of ways depending on the manufacturer. On some at the very top of the touchpad there might be a button in the middle that you can press that toggles the touchpad. On others it might be a sequence of key strokes. For example you might have to Press and Hold the ALT or FN key then hit the corresponding key at the top of the keyboard that toggles it. Most times the correct key to hit will have the icon of a finger pointing at a square area that represents the touchpad.
I found this on your particular model on HPs site. Apparently there is a button or area on the touchpad that is in the upper left hand corner of the touch pad that toggles it on or off.
(1) TouchPad light if Amber: The TouchPad is off.
otherwise The TouchPad is on.
(2) TouchPad on/off button Turns the TouchPad on and off. Quickly double-tap the
TouchPad on/off button to turn the TouchPad on and off.
Here is a link to the document. When it opens up click the Maintenance and Service Guide. It will show you a picture of the Touchpad layout.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&os=4062&product=5111894&sw_lang=&
Apr 18, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Have puchased. a acer wireless optical mouse how do I change over from the present mouse pad?
Theres nothing you need to do much, just plug in the wireless transmitter drive into the usb port, then download driver if one is required. Press the link button, usually a small button located under the wireless mouse.. then you should be good to go. You can disable the mouse pad, usually there is a button or a fn key to disable the mouse pad.
Jan 31, 2011 | Computers & Internet
My mouse causes me to have to gets in the retype all the time cause it goes back up in my sentence or highlights my words blue
This is a very common issue with mouse pads build into laptops computer and can be avoid by moving your hands away from the mouse pad (meaning to open more) during the typing process. You might also want to try to disable temporarily the mouse pad by pressing the mouse button sometimes located on top of your mouse cell or pad or, by pressing FN key along with "F's" key(from F2 to F12). There should be a pad with a hand meaning to either disabling or enabling your mouse pointer.
Finally, try to use and external mouse.
Good Luck!!
Jan 11, 2011 | Computers & Internet
Mouse pad does not work. have tried holding down function key and then pushing F7 key. nothing
If its a Compaq then there is a mouse pad power button at the very top of the pad. If not it may be disabled in the bios and needs be enabled for use. It is not uncommon for a user to disable the mouse pad on a laptop they r annoying.
Jun 24, 2010 | Acer Aspire 5050-3242 Notebook
Unable to use touch pad....rt clk and slide key
If the laptop is that new, the problem is probably the touch pad "disable" button. Look for a small button just above or near the touch pad and make sure the touch pad is not turned off. If you cannot find the disable button, look in your user manual for the touch pad disable.
Jun 01, 2010 | Acer Aspire 5100-5022 Notebook
My my touchpad doesnt worrks
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, option here to Disable,
Feb 23, 2010 | Dell F3534 Touchpad
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
Disable track pad when using the mouse on advent 6311
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
May 11, 2009 | Acer Aspire 3680 Laptop
Frozen touch pad
Hold down the [Fn] key and then press the [F9] Key to toggle touchpad on and off
On my Toshiba Satellite 1135-S155 Fn key is in the middle of Control [Ctrl] and Alt [Alt]
Oct 02, 2008 | Toshiba Satellite 1135-S155 Notebook
Dell Latitude D800 Notebook Logo
94 people viewed this question
Alun Cox
