Question about Kenmore Washing Machines
Sears washer model 110.92282 loud noise (whine?) during agitation and spin modes
  • 3 more comments
  • Kerry English Sep 02, 2010
    The washer is working fine but is making this loud whining or buzzing noise. It started on the spin cycle and now is also during agitation. I'm looking for specific info not a generic list of everything that could be wrong with any washing machine.
    No belt, this is direct drive
    Direct drive, not belt drive
  • Kerry English Sep 03, 2010
    17-year old top loading direct drive Kenmore model 110.92282 80-Series washing machine. Working fine but today started making loud noise (whining or buzzing) first during SPIN cycle and now during both SPIN and Agitation. First was large load of clothes but then I ran empty with just small amont of water. Agitation is fine and water removal is fine. Coupling? Thanks
  • Kerry English Sep 04, 2010
    Hey Jahn27,
    Thanks for your help. The noise was the pump but I followed your diag. path to figure that out. I think the clutch or brake is also dragging. Should the agitator turn during the spin cycle? Mine is but if I grab the top of the agitator during the spin cycle, it easily stops without imopacting the tub speed.
    Thanks,
    Kerry
    President:
  • 1,554 Answers
The problem is definitely not the coupler otherwise there will be no agitation, spin, or drain functions working. The problem is in the clutch and brake assembly.
The clutch hub is attached to the spin pinion gear and as the spin pinion gear turns, the clutch hub also turns. The clutch lining is forced against the clutch hub by the clutch spring and as the clutch hub turns, friction between it and the clutch lining causes the clutch lining to turn.
As the clutch turns, the tab that holds the clutch spring on the lining, pushes the brake cam driver, releasing the brake. The tab on the clutch lining remains in contact with the brake cam driver, holding the brake released and then providing power to the spin tube through the brake release.
It sounds like the brake shoes are not fully released during the spin cycle and still in contact with the brake drum causing the whining noise. The clutch spring must provide the necessary pressure for the clutch lining to turn with the hub and the clutch tab to push the brake cam driver and release the brake.
The clutch spring of your washer is weak or the clutch lining is worn preventing the tab that holds the clutch spring to force the brake cam driver and release the brake completely. The clutch spring must provide the necessary pressure for the lining to turn with the hub without slipping and for the clutch tab to push the brake cam driver and release the brake. Other possible reason is a broken brake cam driver or a worn brake shoe pads.
Since the machine also whines during agitation, you can confirm this condition by observing the agitation action. Only the agitator moves during agitation. The condition is confirmed if the tub moves with the agitator.
Please make sure to accept the solution you find the most helpful. Failure to do so will automatically give credit to the first solution no matter how not helpful it is. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 03, 2010
  • Jahn27
    Jahn27 Sep 03, 2010
    Correction: Drain function is not disabled when the motor coupler is broken. Only the agitation and the spin functions are disabled because the mechanical energy of the motor is not transferred to the transmission but the drain pump is directly coupled to the rear spline of the motor. It makes the drain pump work as long as the motor runs.
  • Jahn27
    Jahn27 Sep 05, 2010
    The agitator turns with the drum during the spin cycle due to some very minimal friction between drive tube and the agitator drive shaft. The friction is very minimal that you can easily hold and stop the agitator without impacting the speed of the drum. What is not normal is when the drum turns during agitation.
  • 11,896 Answers
It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently.Most people suspect the drum bearings but there are many different causes of a noisy washing machine.
Here's a general guide -
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving. (Personally I wouldn't tackle replacing washing machine drum bearings as a DIY job unless a seasoned DIYer. It's a big job, and most washing machines these days have plastic tubs with bearings recessed into them or even completely sealed outer tubs. If you want to have a bash, or maybe have an old washer you may be interested in buying new drum bearings.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  • Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
  • Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  • A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  • A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  • A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
  • Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk. I
Posted on Sep 02, 2010
  • Nate Stansfield
    Nate Stansfield Sep 03, 2010
    I would definitely check the tub bearings and also the motor
  • Nate Stansfield
    Nate Stansfield Sep 05, 2010
    Check your pump and motor first, then coupler and bearings.
  • 10,319 Answers
Check the belt on the motor. A worn belt will slip and make the noises you hear
  • frank thomas wilson
    frank thomas wilson Sep 05, 2010
    A direct drive unit has a fiber coupler between the motor and the transmission. That part has two shear pins most likely sheared off causing the whinning noise
  • 2,272 Answers
Spin bearing issue . he spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
For noises during agitating:
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline. The other possibility is belt if its belt driven washer
Check the belt if its over stretched or loose or worn out. The belt its common on those, remove the front,2 screws on bottom and push in hidden clips between front panel and top and pull down, the front panel comes down, replace belt and lubricate idler pulley, tub bearing ,where transmission spins, should be good
belt spins off, there is a spring loaded idler, just spin belt back on
The other cause can be the motor problem, the motor and its bearing got rusted ,it has to be checked,. If rusted then that is the cause, the motor bearing rubbing other parts of metal while spinning.
For getting required parts you can get it from the online site like www.repairclinic.com Thanks. keep updated for any more query. you can rate this solution and show your appreciation.
  • raj somaiya
    raj somaiya Sep 02, 2010
    You can start by checking the transmission it self.As you mentioned that the noise started from spin cycle now you even get it in agitating cycle:--
    To remove the transmission, all of this must be done: cabinet off, agitator and spacer clips (1 metal, 1 plastic) out, pump off, motor off. Then there are 3 bolts that secure the transmission to the chassis. Tip the machine on an angle to the back, remove the 3 bolts, and the transmission will pull straight out.Now check the transmission and its shaft.If its worn out and needs replacing then for replacing, The new transmission will not come with the motor mounting plate, coupler, or clutch. These parts must be transferred from the old transmission. To remove the clutch, lift off the round metal washer at the base of the output shaft. Then remove the "E" clip and then pry out the wire-looking clip (loose end first) from the inside edge of the 4 tabs. The clutch will now lift off; make sure to retain the plastic insert. Reinstall the parts in the reverse order on the new transmission. Clear the breather hole in the top of the transmission (arrow pointing to it) with a needle or straightened paper clip. Transfer motor mount plate (I usually re-install it upside down from the way it was on the old tranny) and install the new coupler. Gently tap the coupler onto the input shaft until it is flush (I use a ratchet extension so as not to break the coupler with the hammer). Apply small amount of grease to output shaft and slide back into chassis. Assemble in reverse order from this point. Make sure to reinstall the plastic and metal spacer clips before installing the agitator. Once cabinet is back on and machine is back in place, lift the back of the machine up and down to reset the rear leveling legs.
    To disassemble the top of the machine,if in case you are finding it hard to remove then more detailed procedure:--
    Take the console off,Once the control panel is pivoted over backwards, use a small flat screwdriver to pry the brass-colored cabinet clamps (one on each side attaching cabinet top to rear panel of machine, insert screwdriver in front of hole...then push rearward to release). Disconnect lid switch harness from connector coming through top of machine. Pivot top of machine cabinet towards you to a 45 degree angle and pull away from machine. Notice bottom flange of cabinet goes under washer frame and the side cabinet flanges go on top of washer frame (small alignment tabs at all four corners...don't bend them over). Once cabinet is off, you will see the pump mounted vertically in front of motor. If the machine is whining during agitation, most likely you have a bad pump or something in the pump. Sometimes strings, etc will wrap around pump seal so tightly you can't see it. Large flat blade screwdriver should enable you to turn the pump...should turn easily. If you can't find anything wrong with it, you can leave the pump off the motor and fill the machine so it will agitate to see if the noise is gone when the pump isn't attached. Keep in mind, the machine will not spin or drain as long as the lid switch isn't connected to the machine harness because the cabinet is off. You can reinstall the cabinet to connect lid switch to drain unit out once test is done (re-install pump of course so it drains). If noise is gone, replace pump.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My Kenmore washing machine (110.23032101) makes a loud knocking noise on the "Spin" cycle. The adjitator does not always spin along with the tub. Any ideas? Thanks, Curt
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23032101
First of all, in theory and according to the Whirlpool / Kenmore top load, direct drive service manual, the agitator isn't supposed to spin along with the tub.
There is an agitate cam in the transmission that is supposed to raise a gear above the agitate rack.
Please see the following for a complete description.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We had essentially the same problem, loud noises when the machine went into spin mode.
We looked at the service manual and the following parts manual for commercial washers (although the consumer models are basically the same) and thought that the "agitate cam" wasn't lifting the gear high enough, probably less than 1/16 of an inch but enough that it was grinding on the main gear.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
We pulled the transmission
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Replaced everything and the noise disapeared.
The agitator may still turn during the agitate mode but this is mainly due to the oil friction between parts.
Oct 27, 2009 | Kenmore Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Kenmore 8288100 will not agitate properly, i replaced the dog ears but that did not solve the problem. It also makes a loud noise during the agitate cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine. Sears has a parts list for model 82881100.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
It's hard to diagnose what "will not agitate properly" means. However, since you've replaced the dogs and are getting a loud noise during the agitate, try to isolate where the noise is coming from.
Remove the cabinet, see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
If you jumper the two outside pins on the lid switch you will be able to start the washer and listen to the agitating. (We used a couple of bunge cords to keep the back of the washer from flopping around)
When it begins to agitate, listen closely to the transmission. If the noise appears to be coming from the transmission, the problem may be in the agitate cam and / or gear in the gear box.
Look at the gear box diagrams on the Sears site.
We had a major noise problem with our top loader and traced it to worn agitate cams.
Pulling and replacing parts in the transmission is a messy job (14 - 15 Oz. of oil) but it can be done.
Following is how we replaced the cams.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Sep 25, 2009 | Kenmore Washing Machines
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
703 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
