Question about Necchi 3537 Mechanical Sewing Machine
Model 524 FB--stop motion knob difficult to turn. I have turned it and turned it and it doesnt loosen up. Tried turning it both ways and it is still very tight.
4 Suggested Answers
  • 6 Answers
SOURCE: Thread gets stuck around a knob on Necchi 536 FB sewing machine
I'm guessing you would have loosened the tension? Is there grit or something sticky (dirty oil) stuck between the tension discs?
Posted on Aug 26, 2009
Testimonial: "Very helpful suggestions. Cleaned around the upper tension regulator and adjusted top and bobbin tension today. So far, so good. Thanks. "
  • 76 Answers
SOURCE: Stop motion knob has to be turned sometimes to get
check the belt it may need to be replaced.
if you unscrew the screw for the moter a little the moter will drop and put enough pressure on the belt, tighen the srew again and try, can keep making adjustment by lifting moter and tightning the screw a little at a time
Posted on Aug 28, 2009
  • 92 Answers
SOURCE: I cannot loosen stop motion
Sometimes the knob locks so tight it requires a good strong beefy man to loosen it. Turn it counter clockwise!! You can also wind without loosening the knob, just MAKE SURE to unthread the machine and to sew for winding only. It works for all industrial machines, without loosening the knob.
Derek
Posted on Jan 15, 2011
Singer 974 MY NEEDLE WOULDN'T MOVE WHEN I TURN THE HAND WHEEL AND MY HAND WHEEL WOOBLES. HOW CAN I FIX IT?
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
Feb 21, 2014 | Sewing Machines
Stop motion knob will not disengage the needle when winding a bobbin
The stop motion knob on most older sewing machines is very much the same. You should find a small screw on the face of the knob. Loosen this but don't take it all the way out, it is real easy to lose and hard to find a replacement. Loosen it until you can turn the knob counterclockwise past the stop. Now remove the knob and there will be funny shaped washer underneath. Pay attention to how it goes on, you will have to put it back the same way.
Now to the "why" of your problem. The assembly has run dry, no oil, and the hand wheel should turn freely on the center shaft. You may be able to get some oil in with no problem or you may have to remove the motor belt to remove the hand wheel.
I find this a lot on old machines, nothing broken, just no oil.
Good luck,
Bob
Feb 05, 2014 | Montgomery Ward Sewing Machines
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
I cannot loosen stop motion knob so that I can wind a bobbin.
Derek
Jan 15, 2011 | Brother Sewing Machines
I have a Necchi Royal Series 3205FA. I wanted to wind my bobbin. I could not loosen the Stop Clutch Knob. This is a NEW sewing machine. It isn't a strength problem. The part will not turn.
If you have a stop motion dial with little grooves all the way round the best way is to get a wide plade screwdriver, put the plade part on one of the grooves on the left hand side of the dial and give it a thump on top with your hand, that usually does the trick.
Feb 21, 2010 | Sewing Machines
Hand wheel loose
In the middle of the stop motion screw wheel there is a screw, undo the screw and unscrew the stop motion wheel all the way off, you will now see a three pronged washer, take it off and put it in a different position, put the stop motion wheel back on and just tighten finger tight, tighten the small screw all the way, now loosen the stop motion wheel and press on the foot control gently, the balance wheel should move with moving the machine, if the machine turns then start over again, you can put the three pronged washer upside down if you wish.
May 09, 2009 | White Sewing 1418 Mechanical Sewing...
Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Feb 13, 2009 | Sewing Machines
Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Aug 31, 2008 | Sewing Machines
Necchi 3537 Mechanical Sewing Machine Logo
77 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
