Question about Plantronics Explorer 320 Wireless Headset
Bluetooth code needed - Plantronics Explorer 320 Wireless Headset
  • 229 Answers
For most Plantronics products, this passkey is 0000
please rate me +++++
Posted on Sep 02, 2010
How do i get code for bluetooth
First make sure that Bluetooth is on on the CDE-143BT. Press and hold Audio/Setup (below and to the right side of the rotary encoder dial until you enter the Setup mode. Use the rotary dial to get to Bluetooth. Press the Search/Enter button (the center of the rotary dial). Then use the rotary encoder to go through the Bluetooth Settings menu. Press Search/Enter to toggle the current value. After Bluetooth is on, go to Visi M setting and make sure that it is on. Now, you need to go to the Bluetooth settings area of your cell phone when it is within range of the receiver. Tell it to pair with the receiver. Then when it asks for the code enter "0000". This code is hard encoded into the unit. See page 23 of the manual for the CDE-143BT for the code. The manual is available here: http://vault.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf . Surrounding pages show setting the other Bluetooth settings.
Note: the receiver will be acting like a Bluetooth headset. That's why you need to enter the receiver's PIN on the phone.
I hope this helps.
Oct 10, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
Trying to bluetooth pair a Cowan s9 to a jbl charge
Bluetooth connection should be in Settings menu. From there, choose Bluetooth then turn on the Bluetooth transmitter by touching the second option from the left at the bottom of the screen (Bluetooth symbol). After that, press the locate Bluetooth button (the leftmost choice). Make sure your headset is turned on. The player should list your headset once it finds it. There might be a button on headset that needs to be pressed in order to pair it with a device. Once the headset is located it should ask you for the pairing code (usually 0000). If the code is different for your headset, press the rightmost button at the bottom of the screen and enter the code.
Nov 07, 2013 | JBL Charge Portable Wireless Bluetooth...
Need bluetooth code for eonon d2216
D2216 Bluetooth code/pin is 5802
Apr 14, 2013 | Car Audio & Video
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I need the factory pin code I have lost it
Hi,i think you have problem with the code used in pairing your bluetooth device,the default code to connect to your bluetooth device is "0000".
Good luck
Jun 11, 2010 | Samsung SGH-U600 Cellular Phone
Says i need a code to pair with my lg phone
You might have been supplied with a code when you bought your bluetooth headset which you need while connecting to any other bluetooth device.
You need to refer your user manual of the headset for the code.
Please rate if this helps...
Sep 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Need code for my bluetooth
you should put five times zero i.e 00000
Dec 11, 2008 | Blaupunkt Hamburg MP57 CD Receiver CD...
Plantronics Explorer 320 Wireless Headset Logo
20 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
