Question about Endless Summer 153100 Open Flame Patio Heater
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
    Champion:
  • 274 Answers
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Posted on Jul 22, 2011
My Blue Rhino Endless Summer infrared patio heater will light, but after a few minutes, it will go out. I suspect the thermocouple. I took the entire heater apart, removed some dead wasps, dirt, etc. ...
You can purchase all need parts from Uniflame (a division of Blue Rhino) by calling Customer Support
800.762.1142. Have you model number handy when you call.
Hope this helped you.
May 28, 2011 | Endless Summer 2009 Open Flame Patio...
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
I have a full tank of propane - my pilot light is sparking but it will not light? Any ideas on what to check? Thank you, Korby
Korby, I think you meant, your ignitor is sparking and you're not getting gas to the pilot. Since you have a full tank of propane, I can rule out that the tank is empty. However, I believe the tank or at least the tank valve is playing a role in this.
Turn the tank valve completely OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow) until the valve is fully open. Then light the pilot as you normally would. If the pilot lights, you solved the problem. If it didn't, either the pilot light is clogged and needs to be cleaned or the heater's hose/regulator assembly needs to be replaced.
Endless Summer Patio Heaters are made by Blue Rhino. So, if you need parts, that's where you can get them. Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 09, 2011 | Endless Summer 153100 Open Flame Patio...
Flame goes out after 5 to 10 min then have to wait until it cools to relight
Unless, it's the wind blowing the flame out, I'd say the Thermocouple needs to be replaced. This is based on what you said, " have to wait until it cools to relight." The reason for that, is that the burner control valve has to reset itself. You can also check the pilot and pilot orifice for obstructions. Blowing it out with a can of compressed air with a straw nozzle (like you clean your computer with) may also help solve the problem. As insects like to build nests in these heaters, when they are not in use.
Endless Summer Patio Heaters are manufactured by Blue Rhino under the name Uniflame and Endless Summer. You can purchase any necessary parts from them online, if necessary.
Hope this helps you to solve your problem.
Mar 23, 2011 | Endless Summer 233010 Natural Gas...
I have an endless summer patio heater the pilot lights but the does not stay on when you turn the knob to start the heater. Got it on once but then the flame blew out and could not start again
You need to replace the Thermocouple. Endless Summer Patio Heaters are manufactured by Uniflame, which is owned by Blue Rhino. You can order the Thermocouple direct ly from either company. Just make sure you have your Model Number handy.
Mar 06, 2011 | Endless Summer 2009 Open Flame Patio...
I have an Endless Summer patio heater. I have only used one 91) 20# LP gas tank and now afetr replacing the tank the pilot won't stay lite. I have call blue Rhino and they said it is the thermal...
I would have suggested the same thing. It may not be cleaning it needs. If the thermocouple has failed, then it needs to be replaced. I sure would start by giving it all a good cleaning though.
Farmerbear at FixYa.com
Sep 21, 2010 | Endless Summer Blue Rhino 235000...
The pilot light won't stay lit, sometimes it will stay lit and start the heater, but then it just turns off within 5- 10 seconds?
Probably the thermocouple is bad and needs to be replaced. I assume you have enough fuel? . Is this a new unti or is it a bit old?
Mar 29, 2010 | Endless Summer 153100 Open Flame Patio...
Blue rhino endless summer patio heater
Try replacing the regulator, easy fix. If it is not the regulator, the thermocouple could be bad, or the pilot flame may not be strong enough to heat the thermocouple. Take apart the head, if you are comfortable with it, and see if there is a blockage in the pilot assembly.
Jun 28, 2009 | Blue Rhino Portable Patio Heater
Endless Summer 153100 Open Flame Patio Heater Logo
157 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
