Question about Electronics - Others
My 2002 Normad (Skyline) travel trailer running lights are out. Brake, turn, and emerg flashers are good. Is there a fuse for the running lights and if so where is it?
  • 28 Answers
Http://www.skylinerv.com/skyline_manuals.php Above link, you can get the owners manual and maybe find it in there.
http://www.skylinerv.com/contact.php Above link, you can try and contact the maker directly.
Hope you get it sorted out.
Posted on Sep 02, 2010
Where can I find an owner's manual for a 1985 Nomad 5th Wheel,25 foot?
[PDF]travel trailer fifth wheel owners manual - Skyline Corporation
www.skylinecorp.com/faqfiles/1YearTTFWOwnerMan-old.pdf
Nov 15, 1993 - a quality product along with the very best service available in our ..... in this manual includes fifth wheel travel trailers unless otherwise indi-.
Manuals - 1989 & older - RVing-The Midwest Connection
www.rvingthemidwestconnection.com/manuals1989older.htm
1989 Skyline Nomad Manual Request Thank you, Dean Will (4-15-14) ... looking forowners manual for a 1989 Okanagan 5th wheel trailer. ...... Looking for an owners manual for a 1985 Cobra motorhome on a Ford Chasse I have the owners ..
PDF]Skyline Travel Trailer Nomad Owners Manual
www.rjwoerheide.com/skyline-travel-trailer-nomad-owners-manual.pdf
repair manual 2015 used travel trailer - 2015 skyline nomad 190 and 1995 ... bing jabiru 2015 nomad travel trailers/5th wheels - nadaguides ruby nomad ... 1985 service free 1997 skyline nomad 3710 travel trailer lexington, nissan pulsar ...
Jan 01, 2016 | Cars & Trucks
Brake lights not working
check brake pedal switch for conductance and check all fuses again. I unhooked trailer once and blew out a fuse that was independent of the brake light... If you have blinkers working it narrows it down. Check emergency flashers to see if thats working.
Jul 29, 2015 | 2011 Ford Ranger SuperCab
1994 Chevy C1500 truck. No rear brake lights
Most likely this is a brake light switch issue. Replace switch.
If your emergency flashers don't work, all flasher bulbs are fine, but flashing too fast, then check and replace Hazard light switch.
Oct 29, 2012 | 1994 Chevrolet C1500
1995 GMC Jimmy brake lights not working
Brake lights run through the hazzard switch. There are known problems with this, and the multifunction switch. You may need to buy a new hazzard switch and OR the multifunction switch. Before you do that, check the pigtail that goes into the brake switch up by the fender, make sure it's not shorting out up there. Happened to me!
May 06, 2017 | 1995 GMC Jimmy
I have a stock trailer, have tail lights but no brake or stop. My problem is that I can only find one wire going to this unit. Seems to me there has to be a wire for each filament. What am I missing...
the bulbs are 2 filaments right? there has to be 2 wires unless there is a ground wire (3 wires) every trailer has to have a Running light, Left turn, right turn, and ground. th ebrake and turn signals work the same wires. you dont say what kind of truck you have, but some trucks have fuses for trailer lighting. put the 4 way flashers on and see whats wrong. if you have flashers you should have brake.
Sep 22, 2011 | Ford F-250 Cars & Trucks
1997 Chevy Tahoe both turn signals stopped working
Sounds like the flasher unit to me. Normally the emergency flasher and turn signal are separate.
Jul 21, 2009 | 2001 Chevrolet Tahoe
2003 dodge ram lights work on trailer but brake lights
try http://www.etrailer.com/faq-wiring.aspx. They have very good concise information that might help. Check wiring at each light. You can use the emergency flashers and a 12 volt test light to do this.
Make sure each light is grounded well. A loose ground will cause all sorts of problems. Hope this helps. Mike
Jul 04, 2009 | 2008 Dodge Ram Pickup 1500
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
Electronics - Others Logo
70 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
