Question about Brother MFC 210C All-In-One InkJet Printer
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
I was trying to receive a fax but it says paper jam. I took the paper out that was causing the paper jam, and still it is not working.
  • 81 Answers
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
Posted on May 14, 2008
I bought a Brother MFC 210C Printer - Fax - Copier a few years ago, when it ran out of ink I stopped using it for awhile. I just bought new ink cartridges, took the tabs off and put them in and they are...
Perform reconnection inspections on the printer. Attempt to printer documents. The computer should diagnose the condostion either as missing programs or malalligned printer ink or paper or compartments not closed appropiately.
Jan 29, 2011 | Brother MFC 210C All-In-One InkJet Printer
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Paper jam
The issue is with the Paper Feeder roller , either its worn out and needs an replacement.
Apr 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210c
If you are certain that you have removed all paper, try power-cycling your printer. Remove power cord and wait a minute or two then plug back in.
Jan 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
How to replace back cover of MFC-210C?
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Apr 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C problem
press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
Jan 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Always paper jam.....
see here: http://www.fixya.com/support/t214938-paper_jam_showing_but_no_paper_in
Oct 08, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
854 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
