Question about Dell 1125 All-In-One Laser Printer
My Dell MFP 1125 was out of toner and before I could replace it, it powered down one day while I was away. I have tried unplugging it from the outlet and even removing the power cord, but it will not power back on no matter what I do. Have you ever heard of this happening? Does this kind of printer have some type of fuse that can blow? I am in the dark, any help would be great! Jamey
  • 857 Answers
On mine, after some trial and error, I found that if you DISCONNECT the unit completely from the AC outlet for 5 or 10 minutes, then plug it back in again it works.
However please check these things:
1)the power cord wire must be faulty.try replacing that power wire. 2)the power cord wire must not be connected properly either to the electric outlet or to the back of the printer.
3)the electric socket in which u r trying to connect the power wire must be faulty.check out in any other socket.
4)or it could be the short circuit in the main board of printer.if that is the case then it will be very much costly to get it repaired.
Posted on Sep 02, 2010
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
Dell Mono Laser MFP 1125 says no toner found invalid toner it just flashes the above i just added a new cartridge
double check the one you installed to ensure it was installed correctly. You can do this by removing it with the power turned off then reinstall it. Try to power it back on.
Spanish speaking available for all problems Thank you for allowing us to help, please respond with further questions and concerns
Jan 09, 2011 | Dell 1125 All-In-One Laser Printer
I can not receive faxes on my Dell MFP 1125
Hi, I have Dell 1125 All-in-One Laser Printer. I can send faxes by going to fax option and dialing the number.
How can I set it up to receive faxes? keep in mind that I have only one phone line which I use for both phone and fax.
How can I set the ringers in a way that for example at 4th ring goes to answering machine and at 6th ring goes to fax?
I really appreciate it.
Need help fast :)
Mary
Aug 03, 2010 | Dell 1125 All-In-One Laser Printer
Invalid toner or no toner available
These toner cartridges have kill chips on them that are essentially just page counters. It sounds like the chip is either defective or missing. Some low cost refillers will either leave the original on or us very low quality replacements. I would return the cartridge to whoever you bought it from and be sure to purchase a quality refill or original next time.
Feb 16, 2010 | Dell 1125 All-In-One Laser Printer
Dell laser printer MFP 1125 paper tray removal
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
May 31, 2009 | Dell 1125 All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1125 All-In-One Laser Printer Logo
387 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
