Question about Toshiba TZ50V51 50" Rear Projection Television
TV shuts down with Red Light blinking
My TV keeps shutting down and the red light in front keeps blinking with no sequence.
SOmedays it works fine and somedays it keeps doing this.
Please can anybody help in guiding me what could be wrong.
  • 2 more comments
  • YusafRangwal May 12, 2008
    I will go the site that you have provided.
    Thank you for taking the time to answer.
    Will let you know if it worked for me.
    Best regards
    Yusuf
  • Stebben May 12, 2008
    I have same problem. When I unplug tv and plug back in, some times after numerous times it will stay on. I had a tv repair man look at it, and he thought it was my wiring in my house.I have 2 toshiba tvs, and both are doing this. After reading this it seems it is a common thing for these tvs.
  • Anonymous May 16, 2008
    I have unpluged the tv for 20 minutes and it worked fine.Then know it has done the samething ,but it does not do anything know, what is going on?
  • mypreciousha Aug 16, 2008
    we have a similar model toshiba tv TZ250V61 and the same as the above is happening......television will not come on and the red power light keeps blinking...please help.....this is my elder in-laws....the only thing they do is watch tv....lol.......thanks.....
Anyone find a solution, as my same tv model is doing the same.
Posted on Aug 04, 2008
  • Toshiba Master
  • 8,617 Answers
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
it must be your tv was heated on long usage.
sir, try to go to your nearest expert technician. they have tools to use on fixing your tv's hardware. or see if your tv has a warranty to send it back to the place what youve bought it. hope that helps!
CHARCOIS
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
I have a Sony wega 42in tv and the tv keeps shutting off and the red light comes on
Self protection circuit will cause this---see if blinks are in a sequence---5 blinks, pause and 5 blinks etc---that will be a error code and you Can Google the model number to learn what the error is and what in general causes it.
Dec 08, 2012 | Sony Grand WEGA KF42SX200 42" TV
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Tv shut off in the middle of a movie now power light on front just blinks red and does not respond to the remote
Count the number of time the light blinks and if there is a sequence. Google your make and model number and add "blink codes" to the end. The blink code of the red light will tell you what's wrong with your tv. It's a self-diagnostic event.
May 08, 2011 | Toshiba TP43H60 43" Television
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
764 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
