Question about Whirlpool MH6150XM Microwave Oven
Microwave won't turn on. The display is lit and the timer goes on, but no cooking power
  • Whirlpool Master
  • 9,047 Answers
Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If it's quieter than usual - like a fan or engine that should be on is not - then you may have a bad door switch or door switch mount. See this file on door switches.
http://207.234.249.73/mwd/doorsw.txt
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on Sep 05, 2010
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Kenmore microwave 85609 has a 5E code on it
test this steps and fix it. God bless you
  1. Power Issues
    • If your microwave oven won't come on, ensure that the power cord is plugged into an outlet and that the power is on. Replace any blown fuses, and reset a tripped circuit breaker. If the microwave won't run, see that the door is completely closed and that nothing is stuck in it. Ensure that your door is not broken. Replace if necessary. See that you have not started the timer as opposed to the cooking function. Press "Start/Enter" to start your microwave.
    Clock
    • Your display will flash if your power goes out. You must reset the clock. If you do not hear a tone at the end of cooking, ensure that you have enabled the audible tone. Also check that you are using the right command. If your power goes out while your food is cooking, you must reset both the cooking time and clock.
    • Sponsored Links
    Cooking
    • If you see sparks while you are cooking, remove any metal objects or plates with silver or gold trim. If your food is taking too long to cook, ensure that you have selected the correct power level for the food item. Remove any other appliance from the 20-amp circuit line. Additional appliances on the same amp will draw too much power away from the microwave. Also ensure that you have selected the correct food item in the preprogrammed menu. Each microwave has its own error codes. Always read your manual to determine what the error code means. Examples of error codes include "E-11", "E-12" and "E-13." This means that you have a defective sensor, and you must get your microwave serviced. The "SE" error code indicates an issue with your control panel.
    Additional Problems
    • You may hear gear noises, especially a humming noise; the fan will automatically come on while your food is cooking. If your turntable plate makes noise, first clean it, and then see that it is positioned correctly over the roller ring. If your nearby appliances are experiencing electrical interference, move your microwave farther away to correct this problem.
Jul 22, 2013 | Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Panasonic Microwave suddenly won't cook.
Your microwave is detecting an internal shot and shutting down, Most likely due to a faulty Magnetron which is not a part that is worth replacing due to the cost of the part and the decrease in cost of new microwaves.
Mar 06, 2012 | Panasonic Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Even though timer starts the microwave doesn't start cooking
read this post
Parts:
magnetron: W10131681
HV capacitor: 815124
HV diode: W10201950
HV transformer: 8171873
Of note: generic parts are cheaper and will work as well.
Oct 20, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool MH6150XM Microwave Oven Logo
80 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
