Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
The flash drive was around my neck and got into the garbage and got a little moist. It now looks clean but when inserted, it is not read as cruzer and says it needs to be formatted. I have a lot of files on here so I am upset.
    President:
  • 1,566 Answers
Hello there,
I have two suggestions.
1. Try to look for a computer running Mac OS X. Chances are, you can still retrieve the files under this operating system.
2. Format the drive and you can use a recovery software to retrieve your data. Make sure though that after formatting the drive, do not use it unless you have already recovered your files so that the data will not be overwritten. Try to download this recovery software:
http://www.piriform.com/recuva
Let me know how things goes. Goodluck!
Posted on Sep 02, 2010
How to insert sandisk cruzer force usb flash drive into computer?
Usb sockets are all same. Haven't changed. There are other sockets that look similar. HDMI, eSata, display port. I would look very closely to make sure you are attempting to install in the correct port. You might first want to take a look at the flash drive end to make sure that there is no damage. Shouldn't be unless you really tried to force it into wrong port. Other than that, it will fit.
Aug 02, 2014 | SanDisk Cruzer Force 16gb Usb 2.0 Flash...
My 8GB Sandisk Cruzer stopped working today. The ...
if it does this in another computer also, then it;s just dead. if it's new you could take it back to the store and return it.
May 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I bought a SanDisk flash drive a little over a year ago. It opens fine on XP, where I have to enter the password to see my files, but on Windows 7, I'm never prompted to enter my password and thus can't...
The sandisk flashdrive has on the fly encryption. It encrypts it all the time when you remove it and then decrypts it all the time when you insert it unless you have a password. It's possible that sandisk has not encountered the different environment of windows 7 and did not make flashdrives ready for that os.
Dec 25, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Attaching Neck Strap to SanDisk Cruzer Mini 1.0 GB
There should be two holes to thread the neck strap through. I believe you have to loop them in a certain way so it stays there.
Jan 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
4gb SanDisk Cruzer Titanium not working
"limitation is that flash memory has a finite number of erase-write cycles. Most commercially available flash products are guaranteed to withstand around 100,000 write-erase-cycles, before the wear begins to deteriorate the integrity of the storage"
This means that your flash card may have been damaged by not removing correctly Flash card are not that reliable AS previous pen drives
just a sugestion
Dec 22, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
PROBLEM IN PEN DRIVE
Dec 11, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
20 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
