Question about Huffy 26 In Ladies Mojave Gulch Bike
I have an old bike I got at a yard sale. Where should I oil the bike to make sure everything works ok?
  • 3 Answers
You should oil all the gears as well as all the nuts and bolts holding the wheels to make sure that they can turn smoothly when you pedal. I would also recommend you oil the front wheel shaft to make sure that you can smoothly turn the handles.
Posted on Nov 27, 2011
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
I bought it from a yard sale, with no instruction book, and i cant get it to sew a strait stich, it sews zig zag only even if i change knob control, I cleaned it oil it, help?
Hello:
You don't say what model this sewing machine is, or how old. Some older machines had cams that created different stitches. (they sort of look like weird little cogs)
Did it sew ok before you clean/oiled it?
Mar 12, 2011 | Vacuums
My yard machine wont start, i have spark, fuel, and compression. yes there is gas in it. has oil. starter cranks and I pulled the carb off and cleaned the float and everything. the starter almost looks...
Probably not the solenoid they usually work or they don't. Slow cranking could be due to weak battery or bad connections, check those. If all is ok starter motor could be bad. Always check simplest first.
Oct 06, 2010 | Yard Machines 155 Torque Briggs Stratton...
Just bought a DT 125RE from a dealer...driving home from work and the bike just cut out...everything seems ok but have noticed the spark plug is a old one...cant understand this for the company, i bought...
Replace the plug with a new one. If still bad, drain the carb as condensation from the petrol tank may have collected in the float bowl. Please rate my answer. Thanks.
Aug 24, 2010 | 2006 Yamaha DT 125 RE
Engine feels rough, and gear change not that 'smooth'.
honda's run on any fule but stick to 98 if you can as for oil yes synthetic oil is ok a good service wont do any harm so if you can do it yourself all the better
Apr 03, 2010 | 2001 Honda CBX 250 TWister
I have a 2000 gsxr 750 everything sounds ok,runs ok,but oil light comes on and motor powers down like a sensor going off.bike restarts but does it again...
If you are sure you have enough oil, check if you have enough oil pressure.You should be able to borrow or rent this from an auto shop. If your oil pressure is fine,replace sensor.
Aug 20, 2009 | Suzuki GSX-R 750 Motorcycles
Engine idles fine but when i squeeze in the clutch to shift down the motor quits
could be that you have the wrong clutchs. or that you need to take them out squeeze clutch, WITH OUT STARTIN BIKE... lol had to say that i know someone who did. but anyway..... with do so put them back in. and make sure everything looks ok as you do this. sometimes it something lil that make it do it. ck everything oil,fluds the hole 9 yards.
Jul 14, 2009 | 2003 Suzuki VZ 800 Marauder
I bought a mtd yard machine at a yard sale today. It is a model 116-50 6f18 1A36c40219. It seems to work great except it smokes a lot. Is this normal or a problem. Thanks
well its more than likely got to much oil in it or the oil needs to be replaced usually when one smokes thats what it is or some one has glipped it on its top and all the oil is at the top of the engine if its that it will stop sooner or later
May 01, 2009 | Mtd 22" Yard Machine Push Mower
Huffy 26 In Ladies Mojave Gulch Bike Logo
47 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
