I have a rudd acheiver 10 ac unit..the outside fan seizes up..i have wd40'd it, it will spin for a while the seize up again...how can i fix this issue? how does the fan motor come apart? is it permanently sealed? do i need to replace it?
    Master:
    Sergeant:
  • 449 Answers
Yes the bearing in the motor are bad
Posted on Sep 03, 2010
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
Rheem air conditioner fan not working outside
with the unit off: use a stick or something safe to try to move the fan blades to be sure the motor is not seized. If it spins freely :turn the unit on and use stick to give the fan motor a "boost". if it takes off and runs you have a bad fan capacitor which is the most common cause of your problem
Sep 30, 2012 | Ruud UBHC Air Conditioner
Hi' I have a coleman roof top AC unit on a 1991 Tioga i just purchused a couple of months ago! When i turn on the AC it makes a humming sound...no fans spin or no air comes out! If i let it hum for...
The blower motor is seized up...you will need to get up top and remove the cover...then remove the fan blades and the motor and replace the motor....sometimes a temp. fix will be to get WD-40 and then oil worked into the bearings...but that is usually a very short lived fix...
Replacing the motor can be frustrating and time consuming, so you may want to hire someone to do it for you...you may also find that a replacement unit is more cost effective..
heatman101
Jun 14, 2011 | Dometic Rooftop RV Air Conditioner
My laptop not working power cut off afet 10 to 15 minutes the fan is working but outside of air warm air. pl give solution.
An overheating problem will cause the CPU to shut down and if this is not fixed then eventually the CPU will fail. Check the fan to see if it spins freely, also check the heatsink and fan assemble to see if it is clogged with dust, if so loosen the dust and vacuum to remove the dust. If the fan does not spin, then the fan bearing has seized up and the fan needs to be replaced.
Aug 14, 2010 | HP Pavilion dv5000t Notebook
My AC is running inside but the outside unit is not.
could be seized fan motor, failed capacitor, faulty contactor, bad wiring. Turn the breaker off to the unit and try to spin the fan with a long screw driver or something similar but be careful not the bend the fan blade, If the fan will not move don't force it you need a new motor,If the fan spins freely move on open the cover and check the wiring but becareful the capacitor can still have a full charge and shock you even with power off. Other the that you will need a volt meter that can check volts, amps, and capacitors to futher test the unit I suggest calling a local HVAC contractor and having the unit repair and tuned up by have a tune up done you can recoup the cost of the repair with the energy savings from the tune up.
Apr 01, 2010 | Carrier 38CKC036 Air Conditioner
Air conditioning unit seized up and burt the belt.
Yoe will have to replace whatever seized up, if you want AC, If not, just unplug the wires into the unit. That will disable the clutch and the pulley will spin freely. You also need to replace the serpentine belt.
Sep 03, 2009 | 1995 Chevrolet Caprice Classic
My RV rooftop air conditioner fan has seized up
Whether to replace the entire unit or repair it is a tough decision. If the unit is not very old and was working fine before the fan motor froze up, then I do not think that it is necessary for the entire unit to be replaced. With a new unit of course comes the new warranty.
It is not difficult at all to replace the upper unit of the air conditioner. What you have to look for and make sure of is that the ceiling pack or Air Distribution Box (inside unit of AC) that you currently have is compatible with the new Upper Units. Get the part number off of the inner unit and make sure that it is compatible with the part number of the new upper.
Again, it is much less expensive to replace the fan motor than the entire unit (especially Dometic). You could replace the fan motor and get another 10 years out of the AC or, you could replace it and only get 1 year out of it. That is your call.
Just a word of precaution. Dometic Air Conditioners are very hard to find right now due to an industrial accident that occurred at the AC plant. Most distributors and service centers are 6 to 8 weeks out on getting a Dometic AC in stock. That is something else to think about.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
When you turn on the airconditoning.the outside unit just makes a humming noise but does not work, This is a mobile home unit.
First disconnect the power to the unit. The motor may have seized up. Depending on how old the unit is. If the fan does not spin freely after you remove the top of the unit. You may have to replace the fan motor.............
May 06, 2009 | Heating & Cooling
Maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Oct 07, 2007 | Maytag M6D24E7A Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
