Question about SanDisk Sansa e250 MP3 Player
Sansa e260 mi e260 the blue light is on but the screen no work
  • Anonymous May 11, 2008
    I have the same problem and today I ask Sansa for suport.
    I'm waiting.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
I formatted the 16mb-format drive from my sansa e260 now the screen is blank and the blue lights comes on. My computer also doesnt see it. Any ideas on how to reinstall the firmware? Thanks Dumb...
Blue ring: Remove the back and push
softly but firmly on the Rubber rectangle above the battery hold battery in place and turn on(This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Jun 16, 2010 | SanDisk Sansa e260 MP3 Player
The screen on my sansa e260 wont turn on
hold down the power button for 15 seconds and it shoud reset the whole player
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Battery is too low. System shut down
Have you tried removing and replacing your battery? What about the connections and cord, are they damaged at all?
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260 screen wont turn on anymore!
try to get a driver for the mp3 for the computer, and check if the battery is okay.
Jul 26, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 screen not working
does the dial stay on and won't shut off?
Jan 27, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260 doesn't even turn on
Had the same problem, blue light no screen, took the cover off found a small black rectangle block not completely pushed in. the block is located on the right center on the part above the battery and right behind the screen.
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260: Blank Screen
Got it working, I held the Power button down for aprox 30 seconds until the dial light went out then it restarted as normal..
HTH
Nov 12, 2007 | SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
Black screen blue ring
Try holding the Menu button for about 15 seconds.
Apr 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
