Question about Kenmore 24032\24036 Top Load Washer
Kenmore Series 70
I need to access the inner tub. How do I get the machine apart. It doesn't look like it has latches for the top (like the dryer)...how do I get it open?
  • Anonymous Oct 09, 2008
    I have opened yp the dryer & removed the drum & belt. I need to remove the motor since it is almost froze up. How does the motor romove from the fan?
  • 868 Answers
First ,take loose the two screws that are holding the main display panel on,and remove them.Now lift up the display panel by pulling it towards you and lifting so that you can swing the whole panel backward.Now you have to remove the 2 holding brackets that will enable the whole body-cabinet to be lifted off its frame.This is something youll need done by a qualified tech.
Posted on May 11, 2008
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Our Kenmore 70 Series washer bangs so severely during the spin cycle that I'm afraid it's going to launch itself into space. I already used a level to make sure that the machine is sitting properly on the...
Open the lid and check to see of the inner tub is loose. Grap it on opposing sides. Lift on one side and press down on the other side. If the tub moves easily the tub nut located inside / under the agitator at the top of the tub is loose. Also another thing you can do is reset the rear auto adjusting legs by tipping the washer forward until the rear legs are at least 2 inches off the floor and drop it back in place. They will self adjust. Good luck and if none of the above work repost here.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
I lost 23 small rhinestones from jewelry in washer...
Yes. They can get trap in the pump, if they got in between the inner and outer tub.
Dec 12, 2009 | Kenmore 22422 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
Kenmore washing machine washes but does not release the water.
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Mar 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer 70 Series spin cycle not balanced.
You will have to access the tub so you can check the balance system on the tub, either a weight
is missing or a cable is broke or has come off. Should be able to remove back. But you should be able to look at it and tell what happened, everything should look even at the bottom of tub for what ever system is used on it. Someone that has had this model apart could post something that helps you out better. Hope it easy for you to fix on your own with everything being so expensive these days.
Mar 21, 2009 | Kenmore Washing Machines
I am trying to clean out all the gunk that has built up between the inner and outer tub on my trusty Kenmore 60 series washer. I have removed the agitator and tried to life the inner tub out to no avail. ...
there is a special nut called a spanner nut. it is about 1 1/2 inches and needs special tool to remove it to get the inner tub out of the unit. you might be able to remove it with a pipe wrench and then you can get access to the outer tub.
i would recommend just using a washer cleaner and trying that first.
these chemical cleaners are designed to remove residues and are much easier then taking the unit apart.
Feb 23, 2009 | Whirlpool LSQ8000 Top Load Washer
Kenmore series 70
  The whole cabinet comes off on this washer.  Too remove you need to remove 2 screws in console.  These may be in back on the right and left ends of console or may be in front on each end.  If you can-not find them they might be hidden under plastic end trim.  They are located in front of console on both ends.  To remove pry them up from the inner lower edge and peel towards outside of washer.  Then remove screws and shake console back and forth while pulling up.  Console will hinge back.
   Remove to gold colored clips with screwdriver prying at front.  Make note of the position of these clips.  Unplug lid switch harness and pivot cabinet back and off.  The usual spot for a leak is the pump.  Check for stain coming from area on pump where motor shaft enters.  The pump can be removed by taking off the 2 clips.  Also check small diameter hose that enters side of wash tub in back side.  Make sure this is attached to tub.
Oct 14, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
421 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
