Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
I own the Saeco Vienna Superautomatica which I have enjoyed tremendously!!! Unfortunately I made a cup of coffee yesterday and heard a "clunk" then the red light came on. I turned off the machine and turned it back on..the green light came on but I didn't hear the usual mechanical "setting up noise" ...and the red light is on. It seems as though something is stuck. Can you assist me in fixing the problem? When I push the button to make a cup of coffee nothing happens...which is why the red light is on...help..I need my morning coffee.
  • phughes64 Sep 02, 2010
    Sorry but "YOUR" solution is inadequate...trying to understand your message with the misspelled words or incomplete sentences is pitiful. Send my question to someone else. I certainly don't expect to be charged $5.00 for your "solution".
    the first "solution" was absurd...between the incomplete sentences and mis-spelled words absolutely pitiful. After decifering the message, there was no solution.
  • Saeco Master
  • 1,711 Answers
You have not mention anything about the group. Did you try to take it out and put back again. If the problem insist this mean from your description that the clunk is from group motor gears or even the motor gear it self.
In this case the machine must be desasemble in order to find out which part brocken.
If you can remove group and put back again and nothing happents then switch it of and proceed as above since it might just one gear and by replace it the machine will be ok again. However if you try something more then their is a chance to burn the motor also and the cost for repairing it will high and it will be better to thing about a replacement since spare parts are very high compare to a complete machine that might get it from special offers.
You revice all above and if you need any further asistant you can coment back.
ood luck
Posted on Sep 02, 2010
  • espressonist
    espressonist Sep 02, 2010
    You have not mentioned anything about the group. Did you try to take it out and put back again. If the problem insists, this means from your description that the clunk is from group motor gears or even the motor gear itself.
    In this case the machine must be disassembled in order to find out which part Brocken.
    If you can remove group and put back again and nothing happens then switch it of and proceed as above since it might just one gear and by replace it the machine will be ok again. However if you try something more than there is a chance to burn the motor also and the cost for repairing it will high and it will be better to thing about a replacement since spare parts are very high compare to a complete machine that might get it from special offers.
    You revise all above and if you need any further assistant you can comment back.
    Good luck
  • 2,272 Answers
Ensure that all doors are closed, brew groups in tight, water reservoir filled and in place, bean hopper filled, dregs drawer in tight, drip tray pressed in tight, etc. Otherwise you may not be able to proceed to the next step, since the machine will not operate at all if all the parts are not in place.The red light indicating something is wrong with the machine.The red light in most cases comes up due to faulty lid sensor.The machine detects that the lid is open so it does not starts to function.Actually you close the lid,but because the lid sensor is not detecting the ;lid closed it shows up this red light.So as per this ,either its the lid sensor or the lid itself. clean the lid attachments with the machine and recheck.------------- The sensor to determine if the lid to the coffee beans and grinder is closed is about 1/8th of an inch off from the magnet in the lid so it constantly shows the "error" light because the machine senses that the lid is off. The door on the right side where the grounds get dumped also has a sensor issue. So try this :--- leave the door open a little And check if its working or same problem. Also check if its properly filling and the water passing from the pump.Also check the grinder internally,if any coffee grounds got stuck in grinder causing it to make clunk noise and this is blocking the machine and red light coming.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Tengo una saeco vienna superautomatica, y a empezado a perder agua del deposito por la toma de salida, que puede ser?
hola :)
Try changing the seal under the water tank: NM05.006
(Intente cambiar el sello en el tanque de agua)
Jan 23, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
Hi
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
184 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
